Author Topic: Axon constantly resetting when I enable interrupts  (Read 1082 times)
Offline airman00Topic starter
« on: September 02, 2009, 10:28:21 AM »
I was working on interfacing a SmartCard and using interrupts and clock pulses and stuff. Then my Axon started acting all wierd and resetting. After some sleuthing I found the problem to be interrupts.
When I disable interrupts the axon does not reset. However if I don't disable interrupts then it constantly resets. I've commented out uartInit and rprintfInit as well as all the timer stuff, but no matter what I do if I don't put cli() then it will reset.
Any ideas how to fix this problem?
EDIT: Battery is fully charged and I double checked fuse settings - everything checks out.
Take a look this stripped down code:
int main(void)
int i=0;//useless variable
int j=0;//useless variable
/****************INITIALIZATIONS*******************/
uartInit();  // initialize the UART (serial port)
    uartSetBaudRate(0, 4800); // set UARTE speed, for Bluetooth  before was 115200
    uartSetBaudRate(1, 115200); // set UARTD speed, for USB connection
   uartSetBaudRate(2, 9600);
    uartSetBaudRate(3, 115200); // set UARTJ speed, for Blackfin
rprintfInit(uart1SendByte);// initialize rprintf system and configure uart1 (USB) for rprintf
// initialize the timer system (comment out ones you don't want)
// disable all these !!!
timer0Init();
timer1Init();
// timer2Init();
// timer3Init();
// timer4Init();
//timer5Init();
configure_ports(); // configure which ports are analog, digital, etc.
a2dInit(); // initialize analog to digital converter (ADC)
a2dSetPrescaler(ADC_PRESCALE_DIV32); // configure ADC scaling
a2dSetReference(ADC_REFERENCE_AVCC); // configure ADC reference voltage
LED_on();
rprintf("\r\nSystem Warming Up");
//let system stabelize for X time
for(i=0;i<=16;i++)
delay_cycles(5000);
rprintf(".");
delay_cycles(6000);
//read each ADC once to get it working accurately
for(i=0;i<16;i++)
j=a2dConvert8bit(i);
LED_off();
rprintf("Initialization Complete \r\n");
cli();   // disable interrupts.  if this is commented out then the Axon resets
while(!button_pressed()); //wait until user pushes button
while(1) {
control();
delay_cycles(100);
return 0;
« Last Edit: September 02, 2009, 10:41:47 AM by airman00 »
Offline paulstreats
  • Helpful? 20
Re: Axon constantly resetting when I enable interrupts
« Reply #1 on: September 02, 2009, 04:25:07 PM »
does it have any kind of watchdog timer that needs resetting regularly?
« Reply #2 on: September 02, 2009, 04:44:52 PM »
no, and anyways a watchdog timer would be a fuse, with no relationship to any interrupts. ( i think)
  • Helpful? 107
« Reply #3 on: September 02, 2009, 06:10:07 PM »
I think something is causing an interrupt but no ISR has been set up so it jumps to location 0 and reboots.
If your cut down code still gives the issue then try commenting out the stuff that will create interrupts but isn't used - ie the timers, uarts etc
rprintf can also do this if rprintfInit hasn't been called before its first used. So you can always write a dummy routine the just throws away the output ie
void chuck(char c){
and then rprintfInit(&chuck) at the top of your program. That will let you get rid of all the uart stuff as well.
Keep stripping until the problem goes.
« Reply #4 on: September 03, 2009, 09:21:45 AM »
Yea its definitely not a hardware issue, as I tested it with another program and hte Axon was fine.
I redid the code using the latest Axon source code and it works now.
@Webbbot
I'll try stripping it down as well because I'm curious to know what caused the reset.
Last post January 09, 2009, 11:47:06 AM
Last post May 03, 2009, 12:01:39 PM
Last post October 03, 2009, 11:02:45 AM
by ukesh
Last post June 04, 2010, 11:34:30 AM
by yyosef
