Author Topic: Newbie Question - Eep!  (Read 966 times)
Offline RoskvapeTopic starter
« on: September 03, 2009, 10:16:32 PM »
First, I would like to apologize for being pretty uneducated on the subject of electronics.
That being said, I have a seemingly simple dilemma:
1. I need to create a system that is about the size of a watch (or smaller, preferably).
2. It needs to performing the basic function of counting up in minutes and hours, and display this time.
3. Whenever on, it needs to count up. Whenever off, it needs to reset the counter.
Can anyone help me figure out what components do I need for this? I have a vague idea, but I don't know specifics or terminology.
I figure I will need:
A watch battery
A display
A chip of some sort (too vague, I don't know how to buy/make the exact thing I need)
A circuit board?
Any help would be greatly appreciated. :)
Thanks!
Re: Newbie Question - Eep!
« Reply #1 on: September 04, 2009, 03:15:34 AM »
Well, let's see... You need something the size of a watch, having a display like a watch, acting like a watch, turning on with power like a watch and turning off and resetting when power is removed... Tough one...
Hey, what about using a watch!  ;D
Gee, no need to reinvent the wheel, just pop off to the nearest dime store and buy a cheap watch. Then arrange a switch in series with the battery and you're there.
Shouldn't set you back more than a few bucks and less than an hour in the workshop.
Offline Joker94
  • Helpful? 26
« Reply #2 on: September 04, 2009, 06:00:21 AM »
if sorens idea will work go with it, if you build it completely your self it wil cost alot more than a few bucks.
Offline Half Shell
« Reply #3 on: September 04, 2009, 07:55:34 AM »
A few dollars of electronics will also get you the same thing. A micro controller might not even be needed. Look up a 555 timer - they range from a precision far beyond what you need to being able to accurately count out seconds, much like you need. If you want to take a micro controller approach (easier circuit, over all, but slightly more $) then use a small, simple micro controller like any in the ATTiny series. You don't need that much power.
Let us know if you need much more help.
« Reply #4 on: September 04, 2009, 09:28:17 AM »
Wow, thanks for all the fast replies! :)
 I'll give the watch a shot. I am also going to check out the 555 timer. :)
« Reply #5 on: September 04, 2009, 02:46:14 PM »
A few dollars of electronics will also get you the same thing. A micro controller might not even be needed. Look up a 555 timer - [...]
And the display goes where?   ;)
Offline Half Shell
« Reply #6 on: September 04, 2009, 03:41:03 PM »
Simple binary counter, and there are all analog circuits that can convert a given binary number to one of those LED matrixes (I forget their actual name - they're all the number eight until they light up?) Yeah there are ICs for that. So yeah, my suggestion still works. It just won't be a fancy LCD screen.
« Reply #7 on: September 04, 2009, 08:41:09 PM »
Analog???
BCD to 7-seg. is not what I call analog.
Well, your suggestion doesn't work! Trust me, as a guy who has actually build lots of watches, timers etc. with pure TTL back in the seventies, I know the amount of chips needed, the size of the box to hold it (not exactly watch size) and the hole it will burn in your pocket.
Suggesting that, over a digital watch from a dimestore, doesn't really work as proof of sanity ;D
Last post November 11, 2008, 05:08:16 PM
by Trumpkin
Last post October 15, 2009, 04:39:57 PM
Last post December 24, 2009, 02:15:38 PM
by waltr
Last post February 17, 2010, 06:32:09 AM
