Author Topic: How do you delay an analog signal by milliseconds?  (Read 1368 times)
Offline Half ShellTopic starter
« on: September 08, 2009, 09:14:42 PM »
I have a signal from an accelerometer that I wish to slow down by at least a millisecond. I am going to take this delayed signal and feed it into a micro controller's comparator with the "live" signal in - essentially creating a signal for the derivative from the interval. I have a few theories on how to do this, but I wanted to know if anyone knew a good way to delay an analog signal like this.
Thanks in advance for any help.
Re: How do you delay an analog signal by milliseconds?
« Reply #1 on: September 08, 2009, 09:23:17 PM »
Buffer it in your code?
« Reply #2 on: September 08, 2009, 09:40:49 PM »
I'll be doing this to at least three accelerometers. The micro controller will be taxed doing other things - I do not want to try and delay an analog signal constantly - it's too much.
I believe an analog delay can be introduced - purposeful propagation delay of sorts. I want to do it in the most efficient way, however.
« Reply #3 on: September 09, 2009, 01:32:18 PM »
Look up "Bucket Brigade Delay Line".
Perhaps study the delay from a color TV?
« Reply #4 on: September 09, 2009, 05:30:59 PM »
Which microcontroller?
First, set the ADC prescaler to as high as you can. For example, in AVRlib, you'll see:
#define ADC_PRESCALE_DIV128      0x07   ///< 0x07 -> CPU clk/128
Also, you can set up an interrupt that reads the ADC occasionally, while the rest of the time your processor is busy at work.
