Author Topic: Need help with opencv PLEASE!!!!!!!!!!!!!!!  (Read 2507 times)
Offline Hawaii00000Topic starter
« on: September 12, 2009, 05:24:31 PM »
Hey guys and gals, I need some help linking the opencv libraries in Code::Blocks so I can run some demos. I'm a total noob when it comes to C ++ (and programming in general) so I looked online for tutorials. I found some but I couldn't get anything to work. Can anyone help me out? I don't mind if I have change compiler just as long as it works.
EDIT: Finally got it woring using dev c++
« Last Edit: September 18, 2009, 08:09:46 PM by Hawaii00000 »
-Paul Dirac
Its Hawaii Five-O. Get it?
Re: Need help with opencv PLEASE!!!!!!!!!!!!!!!
« Reply #1 on: September 16, 2009, 06:59:25 PM »
Spent 2 hrs on it and still can't get it to work. Has anyone ever use opencv before?
-Paul Dirac
Offline robotcoder
« Reply #2 on: September 16, 2009, 07:06:11 PM »
I just got a hello world to work what kind of issues are you having
« Reply #3 on: September 16, 2009, 07:27:31 PM »
The libraries seem to be working but I still got an error.
Here's the error:
In function 'main':
undefined reference to 'WinMain@16'
Here's the code:
#include "cv.h"
#include "highgui.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
#include <math.h>
#include <float.h>
#include <limits.h>
#include <time.h>
#include <ctype.h>
#ifdef _EiC
#define WIN32
#endif
static CvMemStorage* storage = 0;
static CvHaarClassifierCascade* cascade = 0;
static CvHaarClassifierCascade* nested_cascade = 0;
int use_nested_cascade = 0;
void detect_and_draw( IplImage* image );
const char* cascade_name =
    "../../data/haarcascades/haarcascade_frontalface_alt.xml";
/*    "haarcascade_profileface.xml";*/
const char* nested_cascade_name =
    "../../data/haarcascades/haarcascade_eye_tree_eyeglasses.xml";
//    "../../data/haarcascades/haarcascade_eye.xml";
double scale = 1;
int main( int argc, char** argv )
    CvCapture* capture = 0;
    IplImage *frame, *frame_copy = 0;
    IplImage *image = 0;
    const char* scale_opt = "--scale=";
    int scale_opt_len = (int)strlen(scale_opt);
    const char* cascade_opt = "--cascade=";
    int cascade_opt_len = (int)strlen(cascade_opt);
    const char* nested_cascade_opt = "--nested-cascade";
    int nested_cascade_opt_len = (int)strlen(nested_cascade_opt);
    int i;
    const char* input_name = 0;
    for( i = 1; i < argc; i++ )
        if( strncmp( argv[i], cascade_opt, cascade_opt_len) == 0 )
            cascade_name = argv[i] + cascade_opt_len;
        else if( strncmp( argv[i], nested_cascade_opt, nested_cascade_opt_len ) == 0 )
            if( argv[i][nested_cascade_opt_len] == '=' )
                nested_cascade_name = argv[i] + nested_cascade_opt_len + 1;
            nested_cascade = (CvHaarClassifierCascade*)cvLoad( nested_cascade_name, 0, 0, 0 );
            if( !nested_cascade )
                fprintf( stderr, "WARNING: Could not load classifier cascade for nested objects\n" );
        else if( strncmp( argv[i], scale_opt, scale_opt_len ) == 0 )
            if( !sscanf( argv[i] + scale_opt_len, "%lf", &scale ) || scale < 1 )
                scale = 1;
        else if( argv[i][0] == '-' )
            fprintf( stderr, "WARNING: Unknown option %s\n", argv[i] );
        else
            input_name = argv[i];
    cascade = (CvHaarClassifierCascade*)cvLoad( cascade_name, 0, 0, 0 );
    if( !cascade )
        fprintf( stderr, "ERROR: Could not load classifier cascade\n" );
        fprintf( stderr,
        "Usage: facedetect [--cascade=\"<cascade_path>\"]\n"
        "   [--nested-cascade[=\"nested_cascade_path\"]]\n"
        "   [--scale[=<image scale>\n"
        "   [filename|camera_index]\n" );
        return -1;
    storage = cvCreateMemStorage(0);
    if( !input_name || (isdigit(input_name[0]) && input_name[1] == '\0') )
        capture = cvCaptureFromCAM( !input_name ? 0 : input_name[0] - '0' );
    else if( input_name )
        image = cvLoadImage( input_name, 1 );
        if( !image )
            capture = cvCaptureFromAVI( input_name );
    else
        image = cvLoadImage( "lena.jpg", 1 );
    cvNamedWindow( "result", 1 );
    if( capture )
        for(;;)
            if( !cvGrabFrame( capture ))
                break;
            frame = cvRetrieveFrame( capture );
            if( !frame )
                break;
            if( !frame_copy )
                frame_copy = cvCreateImage( cvSize(frame->width,frame->height),
                                            IPL_DEPTH_8U, frame->nChannels );
            if( frame->origin == IPL_ORIGIN_TL )
                cvCopy( frame, frame_copy, 0 );
            else
                cvFlip( frame, frame_copy, 0 );
            detect_and_draw( frame_copy );
            if( cvWaitKey( 10 ) >= 0 )
                goto _cleanup_;
        cvWaitKey(0);
_cleanup_:
        cvReleaseImage( &frame_copy );
        cvReleaseCapture( &capture );
    else
        if( image )
            detect_and_draw( image );
            cvWaitKey(0);
            cvReleaseImage( &image );
            /* assume it is a text file containing the
               list of the image filenames to be processed - one per line */
            FILE* f = fopen( input_name, "rt" );
            if( f )
                char buf[1000+1];
                while( fgets( buf, 1000, f ) )
                    int len = (int)strlen(buf), c;
                    while( len > 0 && isspace(buf[len-1]) )
                        len--;
                    buf[len] = '\0';
                    printf( "file %s\n", buf );
                    image = cvLoadImage( buf, 1 );
                    if( image )
                        c = cvWaitKey(0);
                        if( c == 27 || c == 'q' || c == 'Q' )
                            break;
                fclose(f);
    cvDestroyWindow("result");
    return 0;
void detect_and_draw( IplImage* img )
    static CvScalar colors[] =
        {{0,0,255}},
        {{0,128,255}},
        {{0,255,255}},
        {{0,255,0}},
        {{255,128,0}},
        {{255,255,0}},
        {{255,0,0}},
        {{255,0,255}}
    IplImage *gray, *small_img;
    int i, j;
    gray = cvCreateImage( cvSize(img->width,img->height), 8, 1 );
    small_img = cvCreateImage( cvSize( cvRound (img->width/scale),
                         cvRound (img->height/scale)), 8, 1 );
    cvCvtColor( img, gray, CV_BGR2GRAY );
    cvResize( gray, small_img, CV_INTER_LINEAR );
    cvEqualizeHist( small_img, small_img );
    cvClearMemStorage( storage );
    if( cascade )
        double t = (double)cvGetTickCount();
        CvSeq* faces = cvHaarDetectObjects( small_img, cascade, storage,
                                            1.1, 2, 0
                                            //|CV_HAAR_FIND_BIGGEST_OBJECT
                                            //|CV_HAAR_DO_ROUGH_SEARCH
                                            |CV_HAAR_DO_CANNY_PRUNING
                                            //|CV_HAAR_SCALE_IMAGE
                                            cvSize(30, 30) );
        t = (double)cvGetTickCount() - t;
        printf( "detection time = %gms\n", t/((double)cvGetTickFrequency()*1000.) );
        for( i = 0; i < (faces ? faces->total : 0); i++ )
            CvRect* r = (CvRect*)cvGetSeqElem( faces, i );
            CvMat small_img_roi;
            CvSeq* nested_objects;
            CvPoint center;
            CvScalar color = colors[i%8];
            int radius;
            center.x = cvRound((r->x + r->width*0.5)*scale);
            center.y = cvRound((r->y + r->height*0.5)*scale);
            radius = cvRound((r->width + r->height)*0.25*scale);
            cvCircle( img, center, radius, color, 3, 8, 0 );
                continue;
            cvGetSubRect( small_img, &small_img_roi, *r );
            nested_objects = cvHaarDetectObjects( &small_img_roi, nested_cascade, storage,
                                        1.1, 2, 0
                                        //|CV_HAAR_DO_CANNY_PRUNING
                                        cvSize(0, 0) );
            for( j = 0; j < (nested_objects ? nested_objects->total : 0); j++ )
                CvRect* nr = (CvRect*)cvGetSeqElem( nested_objects, j );
                center.x = cvRound((r->x + nr->x + nr->width*0.5)*scale);
                center.y = cvRound((r->y + nr->y + nr->height*0.5)*scale);
                radius = cvRound((nr->width + nr->height)*0.25*scale);
    cvShowImage( "result", img );
    cvReleaseImage( &gray );
    cvReleaseImage( &small_img );
« Last Edit: September 17, 2009, 01:35:07 AM by Hawaii00000 »
-Paul Dirac
« Reply #4 on: September 17, 2009, 01:36:06 AM »
Is it because I choose the "Console Application" option?
-Paul Dirac
Last post November 12, 2007, 03:01:49 AM
by stopgo
Last post February 21, 2009, 10:38:16 AM
Last post June 11, 2009, 12:59:33 AM
by spykid99
Last post November 21, 2012, 05:37:44 AM
by karanjthakkar
