Author Topic: Cheap spring steel?  (Read 1370 times)
Offline Razor ConceptsTopic starter
Cheap spring steel?
« on: September 12, 2009, 08:56:37 PM »
I am looking for a cheap source of thin spring steel, around 1/8" wide. I looked on mcmaster but it costs roughly $30 for 25 feet of it.
Also, if the spring steel comes in a roll, how do you change it so that in its normal state it is completely flat? Is that possible?
Offline RoboGeek
Re: Cheap spring steel?
« Reply #1 on: September 22, 2009, 12:37:32 PM »
$30 for 25 feet doesn't sound too bad.
When supplied in a roll it IS flat.... If you cut the binders it will "spring" back to flat, which can be quite violent an event (considering how sharp the endges probably are)...
« Reply #2 on: September 24, 2009, 08:00:22 PM »
I get my spring steal from mcmaster . . .
You can buy it flat, too. The type that comes as a roll just doesn't unfold 100% flat.
Basically lay it out, and put lots of flat heavy things on it. Preferably in a hot environment, and for several days.
Last post September 01, 2008, 01:45:23 PM
Last post February 15, 2011, 03:10:55 PM
by nickc
Last post April 21, 2011, 08:18:20 AM
by Conscripted
Last post January 14, 2013, 06:13:27 PM
by Mastermime
