Author Topic: Bluetooth+USART+PIC16F877a coding help needed  (Read 3225 times)
Offline kazamaTopic starter
« on: September 16, 2009, 04:53:11 AM »
Hi friends. i need some help on bluetooth programming. i'm still new in bluetooth programming. i use PIC16F877a for the microcontroller and eb500 bluetooth module. i'm doing SLAM robot where i need to retrieve data from PIC memory using via bluetooth. but now i'm having some problems on bluetooth programming.
here is my code. could some help me check my coding and guide me, please. need to submit the project by 2 weeks more. i'm using CCS as the compiler.
#include <16f877a.h>
#fuses hs,nowdt,noprotect,nolvp
#use delay (clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#byte TXSTA=0x98
#byte RCSTA=0x18
#byte SPBRG=0x99
#byte TXREG=0x19
#byte RCREG=0x1A
#byte PIR1=0x0C
#bit TXEN=TXSTA.5
#bit BRGH=TXSTA.2
#bit SYNC=TXSTA.4
#bit CREN=RCSTA.4
#bit SPEN=RCSTA.7
#bit TXIF=PIR1.4
#bit RCIF=PIR1.5
#byte portc=7
unsigned char a;
void display(unsigned char c)            // subrountine to display the text on the screen
   while (TXIF == 0);
   TXREG = c;
unsigned char receive(void)               // subrountine to receive text from PC
   while (RCIF == 0);
   a = RCREG;
   return a;
void init(void)                        // subroutine to initialize
   SPBRG=0x81;
   BRGH=1;
   TXEN=1;
   CREN=1;
   SPEN=1;
   SYNC=0;
   set_tris_c(0x01000000);
void main()
init();
while(true)                        // wait for 'ok' to be entered
a = receive();
if (a == 'd')break;
display('H');
Offline radhoo
Re: Bluetooth+USART+PIC16F877a coding help needed
« Reply #1 on: September 16, 2009, 06:04:41 AM »
I've had some great success using an UART Bluetooth module. Might be a solution for you as well, since it offers 9600bps.
See: http://www.pocketmagic.net/?p=924
Regarding the module you're trying to use, do you have the datasheet?
« Reply #2 on: September 16, 2009, 11:58:47 AM »
i have it. but it show the basic stamp programming which i didn't learn and i haven't heard the basic stamp programming. i prefer c programming and use ccs compiler. can someone guide me to finish the bluetooth connection. i want to make the bluetooth connect with pic and it can send and receive the data from pc and also pic memory.
Last post September 19, 2008, 08:28:09 AM
Last post September 21, 2011, 01:54:37 PM
by WaterPig Master
Last post March 31, 2009, 08:48:29 PM
Last post November 26, 2009, 11:18:35 PM
by Webbot
