Author Topic: How do I increase the speed of my robotic snake?  (Read 1307 times)
Offline yash25Topic starter
« on: September 21, 2009, 11:42:12 AM »
Hi!
I'm building this robotic snake , with 8 servo motors. Out of them , 2 are modified servos and they propel the snake forward ( they've been modified for 360 degrees rotation) and the remaining 6 servos are controlled by a microcontroller board for the coiling action of a snake.
Now my problem is that the snake is'nt able to move  as fast as required (i.e the modified servos aren't able to rotate that fast).
How do I increase the forward motion of my snake? Do I add some more motors or do I replace the modified servos with some other motors?
Also, has anyone tried to build sucha bot before?
Yash, India.
Scientists dream about doing great things. Engineers do them.
Re: How do I increase the speed of my robotic snake?
« Reply #1 on: September 21, 2009, 03:21:14 PM »
Bigger wheels and a faster servo will help... but the best way would probably be to replace the servos with gearmotors.
« Reply #2 on: September 21, 2009, 08:37:13 PM »
Hi. Well I've never used gear motors before. So i barely knoe anything about them. Do they work on six volts like servos? and do they have to be modified too for 360 degrees rotation?
« Reply #3 on: September 21, 2009, 08:39:01 PM »
They will work on 6v and they dont need to be modified. They are basically just normal electric motors that are geared down for more torque.
Offline arixrobotics
« Reply #4 on: September 22, 2009, 01:09:25 AM »
but gear motors require a motor driver. it cannot be directly connected to a uC pin coz they require a lot of current.
Offline Joker94
  • Helpful? 26
« Reply #5 on: September 22, 2009, 04:50:45 AM »
It will depend on if he wants to change the direction and controll the motor with presision, if yash25 just wants it to turn in one difrection it won't need a motor driver.
However if he wants it to rotate back and forwards with a MCU he will need a motor conrtoller, you can get an IC chip to do the job for 2 bucks.
the higher current just provides more torque to a un geared motor, the reason for a gear reduction is to provide more torque at an un modified operating voltage.
« Reply #6 on: September 22, 2009, 08:56:48 AM »
No im using the motors only to pull my snake in one direction...not changing the direction or anything. So can I connect it directly to four 1.5v pencil cells?
And Im not connecting these motors to an MCU.
Offline Joker94
  • Helpful? 26
« Reply #7 on: September 22, 2009, 05:33:06 PM »
yes, connecting straight to a battery will do fine , good luck ;D
« Reply #8 on: September 26, 2009, 05:31:51 PM »
[...] if yash25 just wants it to turn in one difrection it won't need a motor driver.
However if he wants it to rotate back and forwards with a MCU he will need a motor conrtoller, [...]
A motor driver is needed in both cases - the only difference is the complexity of the driver!
Last post November 21, 2006, 12:36:24 PM
by JesseWelling
Last post August 24, 2009, 03:21:29 PM
by SmAsH
Last post June 26, 2012, 11:30:44 PM
by roboswarm
Last post August 29, 2012, 04:43:30 PM
by Gertlex
