Author Topic: What transformer do I need  (Read 1556 times)
Offline Joker94Topic starter
  • Helpful? 26
« on: September 22, 2009, 07:28:44 PM »
For my next robot I need to get a piece of nichrome wire or similar to red hot using higher voltage an or current.
I am not 100% sure what amperage i need as i am thinking about using some form of transformer.
any suggestions or circuits that would be usefull
Offline RoboGeek
Re: What transformer do I need
« Reply #1 on: September 23, 2009, 11:37:46 AM »
It will vary on the length of the wire and on the cooling effect from the thickness of the foam you are cutting. It's best to get an adjustable power supply so you can "dial it in" for each job.
  • Helpful? 26
« Reply #2 on: September 23, 2009, 06:00:47 PM »
It is not a foam cutter, it is a fuse igniter there for i need a small transformer on my robot. The other idea i had was have a thin strand of steel wool and have a normal battery or other supply ignit that to ignite the fuse.
Offline chelmi
« Reply #3 on: September 23, 2009, 08:32:26 PM »
A lot easier. AFAIR, a 9V battery was enough.
  • Helpful? 26
« Reply #4 on: September 23, 2009, 10:05:30 PM »
Yeh that is what i was thinking, overall it is going to be cheaper and easyer to setup and reset.
Offline RoboGeek
« Reply #5 on: September 24, 2009, 08:56:18 AM »
Sorry I thought it was for a foam cutter.
For an ignitor you can use tiny 3v or 6v light bulbs and break the glass. They will go up fine from 12v.
  • Helpful? 26
« Reply #6 on: September 24, 2009, 06:04:49 PM »
light bulbs are another good idea, now i have two options. i'll do some testing to find the most reliable and easiest option.
thanks for your input. ;D
Offline Spoil9
« Reply #7 on: September 24, 2009, 09:11:26 PM »
I remember in High School putting LED's in the 120V outlet at our workstations to watch them pop and smoke.  Although that is really a waste of power on a small bot, if you're going for effects...
Knowledge is Power. Power Corrupts. Study Hard. Be Evil.
Last post January 25, 2007, 08:52:07 AM
by Joe
Last post February 22, 2007, 01:57:22 PM
by hgordon
Last post February 05, 2008, 12:29:11 PM
by TrickyNekro
Last post July 06, 2012, 10:56:07 AM
