Author Topic: trouble programming xbee with x-ctu  (Read 2147 times)
Offline toocoolTopic starter
« on: September 25, 2009, 04:40:23 AM »
hi. i have two xbee modules and one xbee usb explorer.i wanted to program the xbee, using the x-ctu software.but i am having problems with the commands in the terminal window of x-ctu
 i want to use the D0 pin of the xbee module as an adc input and i will  have to set it's value to 2. the command for this would be
ATD0 2
but when i enter this, every time the x-ctu softwares gives the response "ERROR"
then i also tried reading the default value for D0 with the command
ATD0
but still it gives "ERROR"
so im totally out of clue here about what to do.... :-[
Re: trouble programming xbee with x-ctu
« Reply #1 on: September 25, 2009, 04:57:33 AM »
which Xbee module?
« Reply #2 on: September 25, 2009, 05:07:27 AM »
The modules are XBee 2.4 GHZ 1mW Communication Module  ---> http://www.trossenrobotics.com/store/p/5200-XBee-1mW-Communication-Module.aspx
The firmware version is 1084
« Last Edit: September 25, 2009, 05:11:09 AM by toocool »
