Author Topic: I want to make a robot beep in certain situations  (Read 1421 times)
Offline m4ntiTopic starter
« on: September 27, 2009, 10:44:02 AM »
Do you know what the part which will do the beeping is called? (Then I'll find how to connect it myself no worries)
Re: I want to make a robot beep in certain situations
« Reply #1 on: September 27, 2009, 02:19:48 PM »
Several options for beeping really; loudspeaker, piezo buzzer, piezo disc etc. Some just needs a supply voltage to beep, other types need an oscillator to drive them.
« Reply #2 on: September 28, 2009, 12:18:41 AM »
Does a buzzer work by supplying voltage?
I just want something like: I pass a 1 and it beeps. Is it possible? Nothing too complex, just to add some fun to it, you know?
Offline galannthegreat
« Reply #3 on: September 28, 2009, 12:37:09 AM »
Yes you can do this very easily. you could try connecting the buzzers positive lead to the output of the MCU and the negative lead to the negative, then send a HIGH signal to the pin for a certain amount of time.
example in pseudo code:
output_HIGH;
delay_500ms;
output_LOW;
Hopefully that is what you wanted. :)
Kurt
« Reply #4 on: September 28, 2009, 12:40:41 AM »
exactly what i wanted :) cheers!
« Reply #5 on: September 28, 2009, 12:46:37 AM »
Cool. I hope it works for you! :)
Kurt
