Author Topic: Axon freezing up when trying to get analog input  (Read 1730 times)
Offline bsamuelsTopic starter
« on: September 30, 2009, 04:29:21 PM »
Hey, I'm using a sharp IR GP2D12 using the following code:
void control(void){
rprintf("starting");
delay_ms(200);
int se=a2dConvert8bit(0);
se=sharp_IR_interpret_GP2D12(se);
rprintf("sensor results: %d \n",se);
delay_ms(2000);
When I press the button to run the code, the Axon gets hung up at int se=a2dConvert8bit(0);. After much troubleshooting, this hang up happens whenever the IR sensor is connected to any of the northern ports (0-15) and everything works fine when a servo is connected to one of the said ports.
Halp?
Re: Axon freezing up when trying to get analog input
« Reply #1 on: October 01, 2009, 06:57:27 AM »
You can't define a function as a value to an int variable. You are also overwriting your own define. Do this:
define se a2dConvert8bit(0)
void control(void){
delay_ms(200);
sensor=sharp_IR_interpret_GP2D12(se);
rprintf("sensor results: %d \n", sensor);
delay_ms(2000);
Offline chelmi
« Reply #2 on: October 01, 2009, 07:49:32 AM »
void control(void){
delay_ms(200);
delay_ms(2000);
I guess you meant #define se a2dConvert8bit(0)?
Anyway I don't see what wrong with his code ;)
Assuming a2dConvert8bit returns an int and sharp_IR_interpret_GP2D12 takes an int as argument and returns an int, the code is perfectly valid.
I don't understand what you mean by "You can't define a function as a value to an int variable." ;)
But I don't know the API, where can I find the declaration of sharp_IR_interpret_GP2D12?
Chelmi.
« Reply #3 on: October 01, 2009, 08:02:43 AM »
chelmi, thanks for calling me out on this . . . it was too early when I replied, brain wasn't turned on yet . . . I was thinking of the WebbotLib API where you put a port number in that SharpIR function and not a sensor value. I've been using WebbotLib a lot lately and got mixed up. Ignore my previous post!
bsamuels, what do you mean by 'gets hung up'?
Whats your battery voltage, and how many Sharp IRs are you using?
« Reply #4 on: October 01, 2009, 04:15:12 PM »
I placed rprintf's for telling me where in the code it freezes.
void control(void){
delay_ms(200);
rprintf("delay successful");
rprintf("a2d conversion successful");
delay_ms(2000);
When I press the button, hyperterminal says:
starting
delay successful
After leaving it for several minutes, it did not continue on to displaying "a2d conversion successful". The only way to get it out of this frozen state is by cutting the power.
Only one IR device is connected, and the battery is 6v.
« Reply #5 on: October 02, 2009, 08:19:48 AM »
What actual voltage is your battery at, as measured with a voltage meter?
Did you modify any other Axon code, such as the ADC initialization stuff?
Also for this:
you should declare se as an int outside of your loop.
« Reply #6 on: October 02, 2009, 04:24:27 PM »
Also for this:
Measured through a voltmeter, it reads an average of 6.5v.
I have replaced all the code in the pwm folder with my own pwm functions for better usability.
Other than that, I haven't made any modifications.
« Reply #7 on: October 03, 2009, 08:13:27 AM »
Try using 100% default code, and see if it still freezes up. If it doesn't, your code is breaking something.
« Reply #8 on: October 06, 2009, 04:32:14 PM »
ok, now it is using all of the original source code except the control file looks like the following:
void control(void){
delay_ms(2000);
With the analog sensor disconnected, hyperterminal prints "starting" over and over every 2000 ms
With the analog sensor connected, hyperterminal prints "starting" ONCE, and does not continue (waited 30s)
I think that the port is fried or something.
« Reply #9 on: October 06, 2009, 09:01:02 PM »
I'm pretty sure something is wrong with your sensor. Are you sure you got the wiring on it right?
The reason I ask is some people mistake the wiring on a sharp IR as ground/power/signal, but its actually power/ground/signal . . .
Check the sensor AND the Axon with a multimeter while its plugged in, too.
« Reply #10 on: October 07, 2009, 09:18:20 PM »
I don't think it's the wiring because I saw how the wires are to be arranged in the diagram in  the manual and wired it accordingly.
SENSOR (facing forward)
Y  B   R
Y  R   B
BOARD  <-outside edge
As for using the multimeter while it is trying to run, where do you want the current to be tested? on the battery, sensor pins, or what?
« Reply #11 on: October 08, 2009, 06:51:45 AM »
I had a similar problem a long time ago, and never found a real reason.
It had something to do with the timer. Try commenting out   delay_ms   and commenting out all the timer_init in Axon.c . For delays use delay_us(delay in microseconds), because that doesn't use a timer.
« Reply #12 on: October 08, 2009, 07:18:45 AM »
Voltage should be measured. Across the sensor pins, and across the Axon pins.
« Reply #13 on: October 09, 2009, 08:39:51 PM »
This worked, I thank you good sir.
But on an off note, any reason why my sensor results are scaling inversely with distance from the sensor? If I have an object right in front (10cm) away from its aperture, I get a result like 90, and if I move an object about 70cm away, I get results like 20-30.
Might this be a wiring problem?
« Reply #14 on: October 09, 2009, 09:46:10 PM »
Nope, thats normal.
Are you using the latest Axon code version?
« Reply #15 on: October 10, 2009, 08:51:29 PM »
Nope, thats normal.
Yessir, but what's the advantage?
Last post April 23, 2007, 10:36:13 PM
by JonHylands
Last post May 23, 2008, 09:31:05 PM
Last post July 21, 2009, 12:56:28 PM
Last post December 18, 2009, 01:49:17 AM
