Author Topic: AVRStudio simulator hangs  (Read 1207 times)
Offline WebbotTopic starter
  • Helpful? 107
« on: October 07, 2009, 11:35:34 AM »
Version 4.16 Build 628
I am currently having problems trying use the simulator to debug a piece of code for the Axon (its worked in the past).
I can compile the program but when I launch the debugger then AVRStudio seems to hang with the CPU at 90%. The debugging windows don't open.
The project options are set up to use the simulator, and ATMega640 at 16MHz.
I have tried:
  • un-installing and re-installing AVRStudio - including telling it to remove all the registry entries during the un-install
  • deleting the project files and rebuilding from scratch
  • rebooting my pc
but all to no avail !
Anyone else had the same problem?
Have tried searching AVR Freaks as well - but can't find anything similar.
Help !
Re: AVRStudio simulator hangs
« Reply #1 on: October 07, 2009, 05:53:38 PM »
I'm not using the simulator so couldn't comment but . . .
v4.17 is out. Try it out, might work:
http://www.societyofrobots.com/robotforum/index.php?topic=6285.msg68988#msg68988
Last post July 01, 2008, 08:35:42 PM
Last post October 13, 2009, 03:10:55 PM
by Maltaeron
Last post July 13, 2012, 10:00:10 AM
by ErikY
Last post April 06, 2013, 09:58:30 PM
by Webbot
