Author Topic: motor gear trouble  (Read 2443 times)
Offline jshalcottTopic starter
  • The Party Has Arived
motor gear trouble
« on: April 22, 2007, 11:41:21 PM »
i have a couple of motors with spur gears on them. i don't need them anymore so i dont care if the gears brake. but i cant get the dang things of using plyers. how else can i get these things off. they dont use  a keyed shaft or anything like that they are just stuck there. i want to atach a clamp hub with a sprocket on them.
DONT DO DRUGS!!!!
Offline Brandon121233
Re: motor gear trouble
« Reply #1 on: April 23, 2007, 08:51:57 PM »
It sounds like its a tight press fit, and it will require a lot of force to remove it; if you don't have a gear puller then you will have to improvise. One, if you don't care if the spur gear gets demolished and if you can get access to a large bench vice, then you could probably just put it in there and "smoosh/squeeze" it off. If you don't have access to a vice then you should quickly heat up the spur gear (with a blowtorch for about 10 seconds), then quickly use a rod a little thinner than the shaft- brace the gear between something and give it a good whack with a hammer. I've included a picture description.
        —Thomas Edison
Offline ed1380
« Reply #2 on: April 23, 2007, 09:38:43 PM »
that's a pretty good looking hammer you got there  :P
I've done that, but without heating and it works good
also sticking needlenose pliers between the motor casing and the gear has worked.
« Last Edit: April 23, 2007, 09:39:24 PM by ed1380 »
« Reply #3 on: April 24, 2007, 09:58:56 PM »
thanks guys the hammer idea worked well
DONT DO DRUGS!!!!
Last post December 03, 2007, 02:17:28 AM
by s80ts0465
Last post January 27, 2009, 12:35:55 AM
Last post March 23, 2011, 10:58:05 AM
by nickc
Last post February 11, 2013, 08:32:36 PM
by waltr
