Author Topic: Serial communication.  (Read 3697 times)
Offline hazzer123Topic starter
« on: April 23, 2007, 01:37:37 PM »
I need to be able to quickly write some code that can write 2 bytes to the COM1 port and then wait to receive 2 bytes back. I dont need any fancy GUI, just the windows console is fine.
Do any of you have any source code you could let me see? Or any recommendations for software?
I have used Hyperterminal so far, but i need to perform maths calculations on the incoming bytes, and so need to write it myself.
My programming knowledge is mainly c++ but basic will also do.
Thankyou
www.icrobotics.co.uk
Offline ed1380
Re: Serial communication.
« Reply #1 on: April 23, 2007, 02:17:37 PM »
do you need to test the com 1 port?
if so do a loopback test
« Reply #2 on: April 23, 2007, 02:23:55 PM »
Nope, i am communicating with a PIC. I am sending it a byte for the speed of the motor it is controlling, and a byte for the direction.
Then, when the PIC gets interrupted, the PIC sends out 2 bytes which are the total number of steps performed.
These are what i need to use in my calculations.
I have the whole thing setup, I just want to embed the communication into my app.
Offline snow
« Reply #3 on: April 24, 2007, 03:26:59 AM »
Here you have a nice tutorial about serial port programming in windows enviroment: http://www.robbayer.com/files//serial-win.pdf.
Offline snow
« Reply #4 on: April 24, 2007, 03:31:39 AM »
And some example class that uses above stuff: http://www.bbdsoft.com/win32.html (com port).
« Reply #5 on: May 01, 2007, 07:48:52 PM »
im guessing no, but does it need to be a realtime calculation? i always save my hyperterminal data as a .csv and postprocess it in excel . . .
Offline sdk32285
« Reply #6 on: May 01, 2007, 08:47:44 PM »
How do you directly save hyperterminal data to csv?
« Reply #7 on: May 02, 2007, 12:43:25 AM »
Hey its ok i managed to do i tusing the tutorials posted, they were fantastic!
BTW, the calculations were not needed real time, so it was easy.
Thanks for your replies
« Reply #8 on: May 02, 2007, 05:02:10 AM »
I perfer to do my postprocessing outside of the microcontroller to improve decimal accuracy and processing speed.
first, make sure you output data with either a tab or comma to space it
then in hyperterminal, click Transfer -> Capture Text
save the data however you want. you can also save it as a .txt file, then just rename the file to .csv
in excel, you need to reorder everything to be comma/tab delimited
Last post July 12, 2007, 05:23:54 AM
by henry
Last post January 14, 2008, 02:52:59 AM
by bootstrap
Last post March 31, 2009, 09:11:58 PM
by mack33
Last post September 18, 2012, 10:06:41 AM
by jkerns
