Author Topic: motor controllers and their operation  (Read 904 times)
Offline dellagdTopic starter
« on: October 13, 2009, 02:30:16 PM »
Hey guys, I wana convert a servo powered bot to motors for speed. What would be the least expensive motor controller and would the motors found at radioshack be suffecient? the robot is the one I am entering in the contest.
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
  • Helpful? 107
Re: motor controllers and their operation
« Reply #1 on: October 13, 2009, 02:42:38 PM »
You need to say how much current your motors need.
The Toshiba TB6612FNG is a nice cheap $9 - $10, and small, dual motor driver if you are in the 1Amp continuous, 3 Amp peak, kinda range.
Available from SparkFun and others.
So choose your motors - based on robot weight, speed/torque required - using Admins calculators.
Then find a controller that can drive the motors.
« Reply #2 on: October 13, 2009, 03:47:51 PM »
ok ok, I think I got it
would 2 of these work well for a reasionalbly fast robot?
http://www.trossenrobotics.com/store/p/4917-GM8-Gear-Motor-143-1-Inline-Offset-3-6V.aspx
from my calculations yes.
can someone tell me how I would use that motor controller webbot listed? the shematics are out of focus and I pretty sure i wouldn't be able to anyway
« Last Edit: October 13, 2009, 03:52:13 PM by dellagd »
I Won!
  • Helpful? 107
« Reply #3 on: October 13, 2009, 05:44:32 PM »
Will your motors work? Are they fast enough?
Well only you know - as you've not given any figures.  ;)
Well if you go with that motor then the stall current at 6v is 660ma which is easily achievable with the TB6612FNG I listed. See http://www.sparkfun.com/commerce/product_info.php?products_id=8905.
It can supply 1Amp per motor continuous.
And if you wanna know how to drive them --- WebbotLib supports that controller  ;D
Last post May 07, 2009, 05:27:20 PM
Last post March 28, 2012, 06:47:48 AM
by joe61
Last post June 02, 2012, 05:17:05 PM
by vipulan12
Last post January 28, 2013, 01:06:25 PM
by joefish41
