Always when searching Digi-Key for something that you want to purchase right away, it is best to check the "In Stock" box below the search criteria, it helps to really narrow down what you want to buy, not what is not in stock and what may take awhile on backorder or special order.
ATmega168 comes in 4 different packages (see the datasheet)
Quote from: chelmi on October 15, 2009, 10:17:06 AMATmega168 comes in 4 different packages (see the datasheet)How am I going to look at the datasheet if I can't find the item? Thank's anyway. Hope you look one day for something you know nothing about and need help finding it. You preach Karma but one day Karma will be your worse enemy. Good luck with that one.
He thought you mean to look at the datasheet of the item on digikey to find out what package it is.
Started by javila Electronics
Started by voyager2 Electronics
Started by catalinene33 Electronics
Started by farnoise Electronics
