Author Topic: The Joy of Improvised Wheels  (Read 2198 times)
Offline ksquaredTopic starter
« on: October 17, 2009, 02:06:12 PM »
As the tin implies, I was trying to make my own wheels.  My best  (I think) idea at the moment was to pack two large washers onto a short cut-off from a wooden doll and put a rubber band over them (if that becomes an issue, glue the Rubber Bands.  What kind of Adhesive? )  Not that I'm precluding manufactured wheels.
As it were, I figured that someone else might be so kind as to share some other schemes that might be used to construct them.  I tend to find mechanical schemes in general interesting and enlightening, and I would appreciate all ideas.  PCV pipe, wood, you name it.
Thanks!
Offline Joker94
  • Helpful? 26
Re: The Joy of Improvised Wheels
« Reply #1 on: October 17, 2009, 07:36:07 PM »
Contact cement should suffice.
« Reply #2 on: October 18, 2009, 12:29:44 AM »
What diameter are you looking for?
« Reply #3 on: October 18, 2009, 01:11:12 AM »
2 or three inches, since you ask; although I could take a little larger.
Gracias, Señoir.
Offline ArcMan
  • Mmmm... Plasma
« Reply #4 on: October 19, 2009, 08:33:10 PM »
I'm certainly not against improvising when necessary, but you are wanting a very common wheel size.  There are hundreds of cheap wheels out there of that size.  Why not just drop a couple bucks on already made wheels?
Offline radhoo
« Reply #5 on: October 20, 2009, 01:53:28 AM »
Gracias, Señoir.
Here are my CD wheels:
http://www.pocketmagic.net/?p=789
3CD's fixed together in screws for a wheel.
Offline MangoBot
« Reply #6 on: October 20, 2009, 05:21:42 PM »
cardboard and rubber bands, CD's, circular things from old stuff like a heat changing dial on a microwave.
« Reply #7 on: October 20, 2009, 11:06:16 PM »
Self-Hijacking (to cut down on threads): How do you mount those tiny metal shafts to wheels, or even anything else?  Also, does anybody have any good techniques for mounting the motors themselves to anything?  Not that I'm not still into wheels.
And thanks again, I really appreciate the help I've been given so far.
Also this could be kinda useful, but still: http://www.societyofrobots.com/mechanics_chassisconstruction.shtml#wheels
Contemplating the first method.
« Last Edit: October 20, 2009, 11:11:30 PM by ksquared »
« Reply #8 on: October 20, 2009, 11:38:52 PM »
To mount a motor to a chassis, or anything else for that matter, most people use a bracket...
Does the motor shaft have a shape to it, or is it just round?
« Reply #9 on: October 21, 2009, 09:41:15 PM »
Round, but two would be basically flat bodied with semi-cylindrical sides.  But these brackets you say... what exactly would you be referring too?  I suppose I could use some simple ties and contact cement.... not sure exactly what kind of ties I'd be using.  I'm open to ideas.  (Jury is still out about attaching wheels to motors.  Servo Horns?  Finite Supply.)
Thanks Again!
« Reply #10 on: October 22, 2009, 04:51:42 AM »
About the mounts, something like this would suffice:
Offline blackbeard
« Reply #11 on: October 23, 2009, 06:56:41 PM »
well i made some here
http://www.societyofrobots.com/robotforum/index.php?topic=9313.0
they're really good and they only need cardboard and just about any adhesive you have. if you need tips on how to make them then let me know
Next step: Give them vaginas
