Author Topic: PROYECT VIDEO TEST AND PROGRAM HELP NEEDED  (Read 591 times)
Offline aventgpsTopic starter
« on: October 18, 2009, 08:00:44 PM »
[youtube]-VyTQuTkU20[/youtube]
I NEED HELP WITH IT, I WANT IT TO STOP WHEN AN OBJECT IS SEEN, THEN TURN PING)) TO SENSE AND CHOOSE THE BEST WAY TO GO
CODE...
#include <Servo.h>
int pin6 = 6;
int pin7 = 7;
int pin13 = 13;
int pin2 = 2; // PIN DE SEŅAL PARA EL PARALLAX
int valor = 0;
int pin2Value = 0;
int timecount = 0; // Echo counter
Servo myservo1;
Servo myservo2;
Servo myservo3;
int bumperisquierdo = 0;
int bumperderecho = 0;
int val = 0;
void setup() {
  // crea objetos y los asigna a mines
  myservo1.attach(9);
  myservo2.attach(10);
  myservo3.attach(11);
  pinMode(pin6, INPUT);
  pinMode(pin7, INPUT);
  digitalWrite(pin6,HIGH);
  digitalWrite(pin7,HIGH);
void loop()
// comienza a moverse el robot hacia adelante
  myservo1.write(100);
  myservo2.write(80);
  myservo3.write(90);
  digitalWrite(pin13, LOW);
  parallax(); //arranca el parallax dentro del loop
  if(timecount < 400)  //lee el parallax mientras avanza, si baja de 400
    miraalaizquierda();   // mira a la izquierda y opera sefun funcion
  else (timecount >400);
    myservo2.write(70);
  //////bumpers//////
      val = digitalRead(pin6);
    if (val == LOW)
      parader();
      val = digitalRead(pin7);
    if (val == LOW)
      paraiz();
void parallax()
  timecount = 0;
  valor = 0;
  pinMode(pin2, OUTPUT); // PONE AL pin2 COMO OUTPUT
  /* Send low-high-low pulse to activate the trigger pulse of the sensor
  digitalWrite(pin2, LOW); // Send low pulse
  delayMicroseconds(2); // Wait for 2 microseconds
  digitalWrite(pin2, HIGH); // Send high pulse
  delayMicroseconds(5); // Wait for 5 microseconds
  digitalWrite(pin2, LOW); // Holdoff
  pinMode(pin2, INPUT); // Switch signalpin to input
  valor = digitalRead(pin2); // Append signal value to val
  while(valor == LOW) { // Loop until pin reads a high value
  while(valor == HIGH) { // Loop until pin reads a high value
    timecount = timecount +1;      // Count echo pulse time
  pin2Value = timecount;
    delay(100);
void miraalaizquierda()
  do
    myservo3.write(10);
    parallax();
    myservo1.write(20);
  while(timecount < 400);
    //   do
    //    miraaladerecha();   // mira a la derecha y opera sefun funcion
    //  while(timecount < 400); // si al voltear a la izquierda no ve obstaculo sale de esta condicional
void miraaladerecha()
  myservo3.write(170);
    parallax();
    myservo2.write(140);
void parader()
  myservo2.write(170);
  delay(2000);
void paraiz()
  myservo1.write(80);
  delay(2000);
Last post March 23, 2007, 07:33:15 PM
by trigger
Last post September 20, 2009, 03:53:02 PM
by MangoBot
Last post October 06, 2010, 09:02:54 AM
by Kelpy
Last post December 07, 2010, 12:12:55 AM
by talon
