Author Topic: begginer problem  (Read 1258 times)
Offline KareemTopic starter
begginer problem
« on: October 21, 2009, 08:00:35 PM »
hey guz
this is the first topic for me in this great site
I'm trying to begin to learn robotics and so and I read the 50$ robot subject and I bought almost all the components needed
but I realized that it is not that easy and looking for some one to help
1-about the microcontroller , I didn't find Atmega8 avr , and bought AT89C52 instead , is there any difference in the circuit or in the way to program it
2-I didn't find Hitec HS 311 servo , only found a normal dc motor 6v
3-do I need solder
try to be simple cuz I'm really a beginner
 thank you very much
Offline corrado33
  • Helpful? 11
Re: begginer problem
« Reply #1 on: October 21, 2009, 09:16:19 PM »
Where are you looking for these products?  The Atmega8 can be found at a lot of different places online.  Such as on digikey.com and search for Atmega8.
The servo is also easily found, but I don't feel like searching for it.  However, in the $50 robot, using 2 DC motors would be A LOT more complicated than a beginner would probably want to deal with.  It involves making at LEAST 2 more circuits that you will have to solder unless you buy them separately, however they are generally quite expensive (for a motor controller at least).  (Yes yes I know you CAN find cheap ones)
Technically, NO, you do not NEED to solder, IF AND ONLY IF you buy a breadboard.  A breadboard is a NON-PERMANENT circuit testing device, however it could be used to temporarily make a robot.  Also, expect to spend more than $50 bucks if you want to go that route.
Learn to solder before you ruin any of the parts you buy, then you won't have to worry about not knowing how to solder again.  There are correct ways to solder, and very incorrect ways as well.  Google how to solder and learn away!
« Reply #2 on: October 21, 2009, 09:33:00 PM »
thank you so much for replying
ok I didn't find servos , they said they're very rare
I'm not in the United States , and I cannot buy from any site
1-you didn't reply about the microcontroler and how I would program it ( I mean what programming language maybe c or basic or boatlaoder or what ) ?
2-I'm ready to go through dc motors as long there is no servo
3-about soldering I mean do I have to get this machine that is used in tutorials for soldering I don't know what is called?
thank u very much
« Reply #3 on: October 21, 2009, 09:35:16 PM »
and ya I've got a board
this thin board........ u know
Offline corrado33
  • Helpful? 11
« Reply #4 on: October 21, 2009, 10:23:13 PM »
Um, I'm not a big expert on programming the microcontroller as I'm just starting myself, but I'm pretty sure you can program in C or Basic depending on the microcontroller you buy.  I don't know what the language is for the $50 robot, but I'm sure someone knows.
Also, I have no idea what machine you're talking about that is used in tutorials for soldering.  All you need is a soldering iron and some solder...
Offline billhowl
  • Helpful? 32
« Reply #5 on: October 21, 2009, 10:37:23 PM »
The microcontroller AT89C52 is 40 pins chips so the pins connection is difference from the $50 robot and it don't have ADC build-in, need external crystals to work, it would be A LOT more complicated than a beginner to deal with.
« Reply #6 on: October 21, 2009, 10:45:00 PM »
thank you all
but you are disappointing me
anyone can give me any clue to start ?
I'm ready to go through it
I'll appreciate it
Offline billhowl
  • Helpful? 32
« Reply #7 on: October 21, 2009, 11:20:02 PM »
I have no choice to disappoint you if you get a more complicated microcontroller to start with, You can learn more about microcontroller AT89C52 from this site, you have long way to go.
http://www.mytutorialcafe.com/index%20Tutorial.htm
edit: typo
« Last Edit: October 21, 2009, 11:40:41 PM by billhowl »
« Reply #8 on: October 21, 2009, 11:50:22 PM »
Thank you for helping me
and thank u for the link
« Reply #9 on: October 28, 2009, 06:59:46 PM »
but I still have this dc motor
so is it important to get the servo , cuz I d'dn't realy find it
and  a friend of mine said to me the at89c52 don't have DCA ( + it doesn't contain ADC )
what can I do ?
this is teling me that I have maybe give up
« Reply #10 on: October 28, 2009, 07:38:14 PM »
what can I do ?
Don't give up - go for something that matches what you have.
Here's a lot of robots based on the 89C52 and DC motors:
http://www.google.dk/search?q=89c52+robot+dc-motor&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:da:official&client=firefox-a
Offline billhowl
  • Helpful? 32
« Reply #11 on: October 28, 2009, 11:05:54 PM »
You can build these Line Follower Robot using DC Motors & 89C52
Line Follower Robot 1
Line Follower Robot 2
Offline MangoBot
« Reply #12 on: October 29, 2009, 02:24:48 PM »
yes you need solder
Last post May 10, 2008, 06:38:05 AM
by shlodo
Last post August 18, 2009, 04:26:57 PM
by MangoBot
Last post January 07, 2011, 11:14:22 PM
by Joker94
Last post August 08, 2012, 04:44:58 AM
by newInRobotics
