Author Topic: line maze solver  (Read 1652 times)
Offline kraz_elecTopic starter
line maze solver
« on: October 22, 2009, 11:22:23 AM »
i wanted to make a line maze solver similar to 3pi robot (www.pololu.com/catalog/product/975) ..can we use at89s52??..it has only 256 bytes ram..is 256 bytes of ram sufficient??..please help.. :-[
Offline GWER57
Re: line maze solver
« Reply #1 on: October 25, 2009, 02:22:21 PM »
It depends on the size of the maze. It also depends on the other variables in your program. But your robot should be able to save one
intersection for every byte of ram you have available. So you should easily be able to work with a maze of 200+ intersections. The key
is to use the ram wisely. :)
GTW
« Reply #2 on: October 25, 2009, 07:24:15 PM »
please tell me little more about using ram wisely...
Offline z.s.tar.gz
  • Linux Guru
« Reply #3 on: October 26, 2009, 05:27:00 AM »
Try to reduce the actual program to the smallest possible. Also, if the maze is a choice of left/right, you could probably use individual bits for the buffer, so that will give you a ton more memory.
« Reply #4 on: October 27, 2009, 07:28:03 PM »
thank you for guiding me ..
Offline z.s.tar.gz
  • Linux Guru
« Reply #5 on: October 28, 2009, 11:19:46 AM »
De nada
Offline MangoBot
« Reply #6 on: October 30, 2009, 08:33:32 PM »
3 ways to do a maze are a wall hugger, random left or right turns, or making a map and finding the shortest way through it.
Offline bsamuels
« Reply #7 on: November 13, 2009, 10:43:51 PM »
Yeah, a wall hugger would probably be the best option here.
Last post April 11, 2010, 07:39:05 AM
by CraftMaster25
Last post January 07, 2009, 01:43:26 PM
by jka
Last post October 21, 2009, 02:17:07 AM
by mdmedlin
Last post October 15, 2010, 09:37:16 PM
