Author Topic: Wanted: c# for Axon MCU Pay $100  (Read 1722 times)
Offline Ai-botTopic starter
« on: October 23, 2009, 05:28:21 PM »
Hi
Not sure this is the riight section of the forum to post this.
Just got my Axon, It's looks good, but I don't have the time right now.
I need someone to code it in c#, I will pay a small donation to you for $100.
1) Source code in c#,  just need one or two lines of documentaion.
2) keep it simple nothing fansy.  One form class.
3) Control one servo and one analog sensor.
4) A slider bar to move the servo.
5) read anlaog signal.....and dispaly it.
That is about it.
You can PM if you want the job.
Thank
Offline chelmi
Re: Wanted: c# for Axon MCU Pay $100
« Reply #1 on: October 23, 2009, 11:35:07 PM »
I'm not sure to understand what you want.
Do you want the code that runs on the axon? As far as I know there isn't any C# compiler and CLI runtime for AVR micro-controllers.
Or do you want a graphical interface to send command to the axon ? If this is the case you still need the part that runs on the axon.
Chelmi.
Offline gaurav.p
  • Go robotics
« Reply #2 on: October 24, 2009, 05:24:33 AM »
woh wat an opputunity ..............but i can't :p
Big Things Come In Small Packages!!!
« Reply #3 on: October 24, 2009, 12:38:26 PM »
Hi Ai-bot, haven't seen you around in awhile.
If you have a program that can send serial data to your USB, then I can write you a program in C for the Axon that takes USB commands to control a servo and the ADC.
I can do it for free as it'll take me maybe 30 min to do, but donations are welcome ;D
« Reply #4 on: October 25, 2009, 12:54:53 AM »
Hi Admin
Yes, it has been awhile since I posted something, becaue I have been very busy.
I am in my final stage for Aiko's new leg.
Cost me a lot of money lately for the legs.
I was planning to use RCB3 for controlling the leg system.
But it cost $600, not something I can't afford right now.
So tried out Axon, hopeuflly it will do the same thing for the fraction of the price.
Yes, C is fine.
If you take paypal then sure I can donate  ;)
« Reply #5 on: October 25, 2009, 07:08:35 AM »
Code is attached. By sending numbers to the Axon USB, it will either command servos, or read and output sensor data back to USB. I put a lot of comments in the code to explain what is going on and how to modify it.
You must first install WebbotLib here:
http://sourceforge.net/projects/webbotavrclib/
Inside the WebbotLib zip you'll find a manual that explains how to set it up. Its really simple, so don't worry.
Use my .c file for the main file, and use the hardware.h to define the hardware. I also included a .hex so you can try it out without compiling. Let me know if you have trouble.
And I'll pass on the money - just put up a few advertisements on your site for me and we'll call it even ;D
