Author Topic: need circuit for home made battery operated atx power supply  (Read 1777 times)
« on: October 25, 2009, 04:14:46 PM »
i'm building a really junky freebot (robot out of free things) that uses an asus tx97-xe motherboard and pentium 1 processor as it's "brain" since it has a parallel port, 2 serial ports and a bunch of isa and pci slots i can use for expansion. what i need is a way to power it whith a 12 or 24v battery without the use of a dc to ac transformer. i'm not sure how to create negative voltage or how to make it so that it doesn't lose power as the battery drains (within reason). i don't want to buy much if anything so my budget is a firm $0. any ideas
Next step: Give them vaginas
Offline ozbot
Re: need circuit for home made battery operated atx power supply
« Reply #1 on: October 27, 2009, 07:20:33 AM »
Well, an ATX power supply is a switch-mode powerbox, transforming 240V AC into several smaller voltages.  Look for the manual online, or find the ATX supply info for  pentium 1 boards.
Look up ATX in wikipedia for some basic info on the variations on ATX boxes.  To create -V, just swap direction of leads on a battery. 12V=12V above gnd, -12V=12V below gnd, just remember that -V needs -V regulator, ie 7912.
I dont think that using an existing ATX box and battery-packing it is the best approach, rather find the voltages needed and create your own powerbox.  I have no idea how fickle a MB is in regard to power consistancy, and have no direct experience making power supplies of this nature, but usually you need clean 12, -12, 5, -5 and 3.3V supplies. There's prob more than a few parts you could scavange from an ATX box, keeping the price down.
hope it all goes well, love seeing junkbots  :)
I was so disappointed to learn that half the people I know are under average........but the other half more than make up for it.
Last post June 15, 2007, 03:06:07 PM
by Ro-Bot-X
Last post July 11, 2010, 04:11:22 PM
by Gertlex
Last post November 04, 2010, 08:37:25 AM
by WhomBom
Last post August 20, 2011, 08:16:45 PM
