Society of Robots
     | Robot Forum | Robot Tutorials | Robot FAQ |
September 10, 2010, 01:02:58 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: SoR Robot Chat every friday night. Join us! (forum integration fix coming when I have time)
http://www.societyofrobots.com/robotforum/chat/
Robot Forum
   Home   Help Search Login Register
Pages: [1]
  Print
Author Topic: need help for micromouse maze algorithm code.  (Read 723 times)
nanslipknot86Topic starter
Beginner
Helpful? 0
Offline Offline
View Profile
« on: October 31, 2009, 07:16:57 AM »
Hi,i am final year student at local university and my final project is to develop the micromouse robot.i use the PIC18f4550,a couple DC motor with encoder and three IR range detector.The sensors are implemented at the front,left and right.my objective of the project is to memorize the map when the robot get into the maze area while it try to find the way out by its own.the design of the maze are 5x5.my problem is how can i make the algorithm of simple 5x5 maze map so that the robot can memorize the map while it try to find its way out without crashing the maze's wall. i have made the code for algorithm but the robot not execute as my requirement.it would be pleasure if somebody could give me the hint or suggestion of the maze algorithm that i made. i attach my code for your reference. for your information i use PICbasic microcode studio version 2.2.1.1 to make my code of maze algorithm. Thanks.
The code in format pbp file.
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 10/28/2009                                        *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
define osc 8
'defenition
DEFINE CCP1_REG PORTC   ' Hpwm 1 pin port
DEFINE CCP1_BIT 2       ' Hpwm 1 pin bit
DEFINE CCP2_REG PORTC   ' Hpwm 2 pin port
DEFINE CCP2_BIT 1       ' Hpwm 2 pin bit
DEFINE ADC_BITS 8       ' Set number of bits in result (8, 10 or 12)
DEFINE ADC_CLOCK 3      ' Set clock source (rc = 3)
DEFINE ADC_SAMPLEUS 50  ' Set sampling time in microseconds
MWPWM1 VAR PORTC.2       'PWM MOTOR 1
MWPWM2 VAR PORTC.1       'PWM MOTOR 2
MRCW1 VAR PORTD.4
MRCCW1 VAR PORTD.5          'MOTOR RIGHT DRIVE
MRCW2 VAR PORTD.6
MRCCW2 VAR PORTD.7          'MOTOR LEFT DRIVE
TRISD.4=0
TRISD.5=0
TRISD.6=0
TRISD.7=0
TRISA.2=1
TRISA.1=1
TRISA.0=1
ADCON1=%00000000
SENSOR1 VAR BYTE
SENSOR2 VAR BYTE
SENSOR3 VAR BYTE
i var byte 'step in one box
junction var byte 'at the jubction
status_sensor var byte '0 - 1, 1 - 2, 2 -3
porte.7=1       'activate internal resistor
'kire distance
distance var word   'distance in pulse
counter var word
stat var byte
portin var portd.0
input portin
HPWM 1,50,500
HPWM 2,50,500
'MAIN PROGRAM
MAIN:
        status_sensor=0
        GOSUB IR1     'JUMP TO IR1 SUBOUTINE
        GOSUB IR2     'JUMP TO IR2 SUBROUTINE
        GOSUB IR3     'JUMP TO IR3 SUBROUTINE
        'maze algorithm'
        i=0
        select case status_sensor
            case 0                  'no detection
                gosub fwd           'go straight
                pause 1000          'delay for 1 second
                gosub stopmotor     'robot stop
                    case 4             's3 detect
                        gosub left     'turn left
                                case 2  's2 detect
                                    gosub right   'turn right
                                            case 1 's1 detect
                                                    case 6  's2&s3 detect
                                                    i=0     'i for per block=0
                                                    junction=i  'junction at block
                                                    i=i+0       'block+1
                                                        i=i+1      'block+1
                                                            case 5  's1&s3 detect
                                                            i=i+0     'block+1
        case 3  's1&s2 detect
        i=i+0         'block+1
        i=i+0      'block+1
        case 7  's1,s2,s3 detect
        gosub bwd  'reverse
        i=i-0      'block-0
        gosub uturn  'make uturn
        END SELECT
            END SELECT
                END SELECT
                    END SELECT
                        END SELECT
                            END SELECT
                                END SELECT
                                    END SELECT
GOTO MAIN    'LOOP TO MAIN FOREVER
'SUBROUTINE PROGRAM
IR1:
    adcin 0, SENSOR1
   IF SENSOR1>82 THEN
        status_sensor.0=1
   ENDIF
RETURN
IR2:
   ADCIN 1,SENSOR2
    IF SENSOR2>82 THEN
        status_sensor.1=1
     ENDIF
RETURN
IR3:
   ADCIN 2,SENSOR3
IF SENSOR3>82 THEN
        status_sensor.2=1
     ENDIF
RETURN
gosub fwd
distance=179
gosub countnstop
gosub stopmotor
pause 10000
return
gosub right
distance=179
gosub countnstop
gosub stopmotor
pause 10000
return
gosub left
distance=179
gosub countnstop
gosub stopmotor
pause 10000
return
gosub bwd
distance=179
gosub countnstop
gosub stopmotor
pause 10000
return
gosub uturn
distance=179
gosub countnstop
gosub stopmotor
pause 10000
return
fwd:
    HPWM 1,50,500
    MRCCW1=0
    MRCW1=1
    HPWM 2,50,500
    MRCCW2=1
    MRCW2=0
RETURN
stopmotor:
    MRCCW1=0
    MRCW1=0
    MRCCW2=0
    MRCW2=0
RETURN
bwd:
    HPWM 1,50,500
    MRCCW1=1
    MRCW1=0
    pause 100
    HPWM 2,50,500
    MRCCW2=0
    MRCW2=1
    pause 100
return
left:
    HPWM 1,50,500
    MRCCW1=0
    MRCW1=1
    pause 100
    HPWM 2,50,500
    MRCCW2=0
    MRCW2=1
    pause 100
return
right:
    HPWM 1,50,500
    MRCCW1=1
    MRCW1=0
'    pause 100
    HPWM 2,50,500
    MRCCW2=1
    MRCW2=0
'    pause 100
return
uturn:
    HPWM 1,50,500
    MRCCW1=1
    MRCW1=0
'    pause 100
    HPWM 2,50,500
    MRCCW2=1
    MRCW2=0
'    pause 100
return
countnstop:
    stat=0
    counter=0
    while distance>counter
        if portin=1 then
            stat=1
        endif
        if stat=1 and portin=0 then
            counter=counter+1
            stat=0
        endif
    wend
return
Logged
Pages: [1]
  Print
Jump to:
Subject Started by Replies Views Last post
best maze algorithm
Electronics
mobz 5 2060 Last post September 26, 2007, 11:49:14 AM
by Ro-Bot-X
Simple maze traversal algorithm
Software
prolog 9 2104 Last post January 04, 2008, 09:58:29 AM
by prolog
Micromouse maze solving Robot
Robot Videos
mahavir.coep 0 3268 Last post July 05, 2008, 05:46:18 AM
by mahavir.coep
Line Maze Solving Algorithm - How It Works
Software
RoboticsProfessor 2 2274 Last post May 11, 2009, 01:49:38 PM
by RoboticsProfessor
Powered by MySQL Powered by PHP Powered by SMF | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Advertise on this Forum
