Author Topic: Help! DC motor with hall sensors  (Read 2198 times)
Offline fang-weiTopic starter
« on: April 25, 2007, 01:51:29 AM »
Hi!
I want to use a DC motor (EMG30) which has 2 hall sensor outputs instead of optical encoder. Does somebody know which kind of outputs are these? Square?  I will control it with a L6205 chip and need to know if it's compatible.
Thanks for your help! I found no spec on datasheets ...
Have a nice day!
Re: Help! DC motor with hall sensors
« Reply #1 on: April 27, 2007, 06:45:45 AM »
so no one has answered this and I dont know a good answer either, but maybe this will help . . .
A hall sensor detects a change in magnetic field, and can be used for encoders. Optical encoders will give a sharp square wave, but hall effect sensors will give a more rounded signal.
I am assuming that since they are using the sensor for the encoder it should be fine . . . because its two sensors, I am assuming its a quadrature encoder (detects motion both clockwise and counterclockwise).
Last post January 02, 2011, 11:59:44 AM
Last post February 24, 2011, 12:21:41 PM
Last post May 30, 2012, 06:19:55 AM
by mstacho
Last post June 08, 2012, 10:51:38 AM
by ahes
