Author Topic: Build own RF remote control  (Read 2196 times)
Offline praveen_khmTopic starter
« on: November 05, 2009, 04:20:56 AM »
I need to build my own remote control for a car. I know we can easily by using a cheap circuit from a remote car. However, I need to do it on my own using TX/Rx circuit.
Searched the forum, google. but did not get enough results. Request anybody here to help me in this. This is my first request and sure you guys would help me on this.
Also if someone can guide me like the 50$ robot, it would be very helpful as it can take me step by step in building the same.
Thanks,
Praveen
« Last Edit: November 05, 2009, 04:23:05 AM by praveen_khm »
Robot building is all about sharing and learning
www.robotplatform.com : Beginners guide to Electronics & Robotics
Offline blackbeard
Re: Build own RF remote control
« Reply #1 on: November 07, 2009, 07:26:05 PM »
bump for another interested viewer
Next step: Give them vaginas
« Reply #2 on: November 08, 2009, 11:44:47 PM »
Hey friends,
Anybody to help me on this please?
I need your help to progress on this...
Thanks,
Praveen
Offline gaurav.p
  • Go robotics
« Reply #3 on: November 10, 2009, 07:27:31 AM »
Big Things Come In Small Packages!!!
Offline blackbeard
« Reply #4 on: November 10, 2009, 11:28:36 AM »
would i be able to use a max323 on the transmitter and an arduino on the receiver?
Offline hopslink
  • Helpful? 14
« Reply #5 on: November 10, 2009, 12:19:27 PM »
MAX323 is an analogue switch. Were you thinking of a MAX232 or MAX3232?
The Tx/Rx pair linked above almost certainly has logic level serial inputs/outputs so you could connect directly to an Arduino. To connect the Tx to a PC or other true RS232 input you would typically use a line driver like the MAX232 to convert down to logic levels.
Offline blackbeard
« Reply #6 on: November 10, 2009, 12:35:05 PM »
oops i meant to type max 232 as in serial to ttl
Last post January 12, 2007, 09:52:29 PM
by JesseWelling
Last post April 22, 2007, 04:50:57 AM
by jschoormans
Last post July 08, 2007, 09:26:49 AM
by megaman935
Last post July 07, 2007, 07:45:47 PM
by ed1380
