Society of Robots
     | Robot Forum | Robot Tutorials | Robot FAQ |
Welcome, Guest. Please login or register.
Did you miss your activation email?
November 20, 2009, 08:44:58 PM
Login with username, password and session length
Search:     Advanced search
Sept 30th - New Price - Axon is now $94
Robot Forum
72,665 Posts in 9,267 Topics by 5,290 Members
Latest Member: robertelson
* Home Help Help Login Register
Pages: [1] Print
Author Topic: Disengaging a motor from the wheel  (Read 150 times)
baalexanderTopic starter
Beginner
Helpful? 0
Offline Offline
View Profile
« on: November 06, 2009, 03:24:09 PM »
Planning out my first robot. I have a computer science background, but am trying out a field where the inputs aren't always keyboard entries and the output isn't always a screen. It feels liberating so far.
The robot I'm planning will follow a person, but also be human pull-able (think like a tilted movers dolly). I don't want the motors to be engaged to the wheels when the user is pulling because that seems like a damaging action to the motors and adds extra resistance to the user.
Do you know what I should be searching for to find a way to disengage the motors? I'm not sure if this is like an extra clutch type system, or can be built into the gear head, or if some motors can go into free spin. If you need more information, please let me know!
Logged
SmAsH
Supreme Robot
Helpful? 62
Offline Offline
SoR's Locale Electronics Nut.
View Profile WWW
« Reply #1 on: November 06, 2009, 03:45:37 PM »
There are quite a few ways of doing this, it just depends on which you want Smiley
Although spinning a dc motor while its not moving doesnt really damage it at all, its how a generator works...
The one i am thinking about involves physically detaching the gear from the wheel gear, then re-attaching when the motors need to drive.
Logged
you can call me James.
check out my site
Razor Concepts
Supreme Robot
Helpful? 33
Offline Offline
razorconcepts.net
View Profile WWW
« Reply #2 on: November 07, 2009, 06:25:24 AM »
I would just leave the motors attached and use it to recharge the bot's batteries  Grin
Logged
SmAsH
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #3 on: November 07, 2009, 02:13:39 PM »
Yeah, i had that exact idea while i was writing my previous post...
Logged
check out my site
Beginner
Helpful? 0
Offline Offline
View Profile
« Reply #4 on: November 09, 2009, 02:43:13 PM »
Thanks for the replies!
From my basic understanding, turning the motor via the wheels will generate voltage, which goes to the wires. If I go with the simplest approach and do not disengage the wheel from the motor when being pulled, is it right to assume I'll need a stronger diode to keep the back-emf from hurting the rest of the circuit (and possibly a bigger resistor for LEDs or whatever down the line of the motor)?
Using the motor as a generator looks like an awesome idea. Probably too much for my first iteration, but definitely something for the future. I couldn't figure out how to switch from motor to generator at the circuit level. Maybe like a transistor switch so if a high enough voltage from the motor, send to a battery charging control? Are y'all aware of any projects that have done something similar?
Logged
SmAsH
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #5 on: November 09, 2009, 03:19:40 PM »
Well, if you have a diode on the circuit then the motor wont be able to turn in the other direction...
Do you only want the motors to turn in one direction? If you have a motor controller you wont need diodes.
well, you could have a switch that takes the motors leads from the controller to the battery, quite simple...
The only problem with measuring the voltage on the motor leads is that there will be voltage when the motor is being run from the battery...
Logged
check out my site
Soeren
Supreme Robot
Helpful? 33
Offline Offline
Whatever Works... Works.
View Profile
« Reply #6 on: November 10, 2009, 04:42:41 AM »
Just measure sign and magnitude of the current instead.
Releasing the wheels:
 decouple an electromagnetic clutch.
 use a centrifugal clutch (which only couples when the motor reach a certain speed).
 manually remove a single spur gear mounted for the purpose.
 mount the wheels with some kind of locking system that can be released to let them spin freely on their axle.
 etc.
Logged
>>> Whatever Works... Works <<<
Pages: [1] Print
Jump to:
Subject Started by Replies Views Last post
need advice on navigation, wheel configuration, motor types, etc.
Misc
thomasaconway 7 2557 Last post October 09, 2006, 04:10:23 PM
Need help mounting wheel to DC motor
Mechanics and Construction
sotu 1 1134 Last post June 21, 2007, 11:22:58 AM
by brijesh
Wheel Chair motor controller
Electronics
Asellith 7 1150 Last post March 21, 2008, 11:50:25 PM
by bulkhead
motor, gears, and wheel sets
lorenb 2 548 Last post March 25, 2009, 11:40:48 PM
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Advertise on this Forum
