Author Topic: $50 robot problem (Fried Chip?)  (Read 1923 times)
Offline ksquaredTopic starter
« on: November 07, 2009, 10:34:35 PM »
I bread boarded the circuit for the $50 dollar robot - minus the sensors - but it doesn't work.  I've checked and rechecked the thing, but yes, it works.  I was using the 6-pin deal.  Is there any good way of seeing if that chip is fried?  I was using the AVRISP mkII at my dad's recommendation (as had to order a bunch of stuff from digi-key anyway.)  When I use AVR studio, it always says "connection failed."
Oh, and thanks.
« Last Edit: November 07, 2009, 10:39:48 PM by ksquared »
Re: $50 robot problem (Fried Chip?)
« Reply #1 on: November 07, 2009, 10:36:18 PM »
Try this code:
http://www.societyofrobots.com/robotforum/index.php?topic=7836.0
And attach an LED to any output port. If the LED flashes you are good! (Assuming you are using mega168)
Offline galannthegreat
« Reply #2 on: November 07, 2009, 11:49:56 PM »
Just a note, check the orientation of your programmer. I personally have attached it backwards many times.
Kurt
« Reply #3 on: November 29, 2009, 10:50:46 PM »
Would this circuit http://www.google.com/url?sa=t&source=web&ct=res&cd=1&ved=0CAcQFjAA&url=http%3A%2F%2Fwww.tuxgraphics.org%2Fcommon%2Fimages2%2Farticle09043%2Ftest-circuit-led.pdf&rct=j&q=Atmega8+test+circuit&ei=Xk4TS4moD9L-nQeFw4nDAw&usg=AFQjCNGvR-z_mqERrzuatTI9Ay7jxb_eFg do it?
I use the Atmega8.  Is that hex file compatible?  If nothing else, I can periodically oscillate the output pins myself....
oh and Thanks a lot!
Previous Solution: Upgrade AVR studio.  Yea free tech support.
