Author Topic: servo noise interfering with camera  (Read 872 times)
« on: November 15, 2009, 10:11:16 PM »
so i have 2 continuous rotation servos powered by the 5v on my arduino but i also connted a 5v wireless camera transmitter to that same 5v slot in parallel. the problem is when the servos move they drive the camera nuts and you can't see a thing.  when the motors have resistance the noise gets worse. any way to clean the servo noise?
Next step: Give them vaginas
Re: servo noise interfering with camera
« Reply #1 on: November 15, 2009, 11:18:24 PM »
Maybe not use the regulated 5v? Consider getting a 6v battery for your servos...
« Reply #2 on: November 16, 2009, 04:48:05 AM »
[...] any way to clean the servo noise?
Yes, like with any other DC motor - subject's been up recently, use the search facility.
« Reply #3 on: November 17, 2009, 07:33:54 PM »
5v regulator seems to have done allot to reduce noise however there is still a problem when the servos are worked hard though at least now they can move while the camera is rolling. any tips on how to fix the rest? also the other threads which you speak are hard to find.
Offline Gertlex
  • Helpful? 23
« Reply #4 on: November 17, 2009, 07:38:06 PM »
A "throw money" solution would be a servo controller.
I
« Reply #5 on: November 17, 2009, 08:28:39 PM »
what about a "throw worthless junk" solution
Last post February 27, 2007, 07:51:39 PM
by toastman
Last post April 25, 2008, 06:58:30 PM
by videorov
Last post June 24, 2009, 05:53:00 PM
by Joker94
Last post December 23, 2011, 03:37:35 PM
by ArtBot
