Author Topic: Confirm $33 HDPE Sheet?  (Read 1505 times)
Offline jj911Topic starter
« on: November 15, 2009, 11:15:26 PM »
http://kmac-distribution.com/Plastics/hdpe-colored-sheet.htm
is that really $33 bucks for a HDPE Sheet?
KS-16086     0.090     36     48.5     Black     10     $32.04
Re: Confirm $33 HDPE Sheet?
« Reply #1 on: November 15, 2009, 11:20:50 PM »
yes, but consider the size, 36x48... Ill admit i have seen it cheaper before but meh...
Offline Gertlex
  • Helpful? 23
« Reply #2 on: November 16, 2009, 03:54:21 PM »
Shipping costs are going to be horrid for something like that, at least if they don't charge a flat shipping fee based on weight.
I
« Reply #3 on: November 16, 2009, 04:17:10 PM »
Buy plastic cutting boards, some are made of HDPE.
« Reply #4 on: November 18, 2009, 09:19:18 PM »
you found cheaper 36x48? dont forget these are .9 inches. if so where would be the best source to buy those from?
im buying a sherline 2000 cnc mill, that should be able to cut this without splintering and cracking right?
thankyou
Offline billblack
« Reply #5 on: December 13, 2009, 06:04:24 PM »
 ???    ummmmm...that is a .090 sheet not 0.900 sheet.
If you have not yet purchased it, try:http://www.usplastic.com/catalog/item.aspx?itemid=23869&catid=705
24x48, 0.750 inch thick, 91 bucks. Not a great price, but not bad.
A Sherline will cut it, but be sure to google "Machining HDPE plastics" before you start doing much milling. Many plastics like sharp bits and high feed rates to reduce the amount of heat energy transferred to the material by the tool. Melted edges look bad and the stuff REALLY stinks when it catches on fire.
Offline Joker94
  • Helpful? 26
« Reply #6 on: December 13, 2009, 06:48:05 PM »
do you have any plastic supply places where you are. I have recently bought some plastic and what i have found is that if your fine with a few scratches and the like off cutts are the way to got. I got 460x580 piece for $5 bucks and the plastic is almost knew.
But shipping is the part that gets you
Last post May 02, 2007, 05:40:56 PM
Last post September 04, 2009, 04:36:22 PM
by Joker94
Last post November 30, 2009, 01:54:19 PM
Last post June 01, 2011, 11:25:19 AM
by Aberg098
