Author Topic: Wiring a Sharp IR Sensor GP2Y0D810Z0F  (Read 2679 times)
Offline GertlexTopic starter
  • Helpful? 23
« on: November 17, 2009, 07:08:02 PM »
I bought this sensor more than a year ago and am finally getting around to playing with and using it.
The data sheet is here:
http://document.sharpsma.com/files/gp2y0d810z_e.pdf
I've tried doing the following test with an Axon for power, and a Multimeter for measurements:
GND (4) to Axon ground pin (E.g. A2 pin trio)
Vcc(11) to Axon center row pins (again, A2 trio)
Then Multimeter to GND and Vo(13)
All measurements end up being in the 0 to +- 5mv range.
I'm pretty sure that I'm doing the wiring wrong for this sort of sensor.  Someone with a better knowledge of reading data sheets know what to do here?
Thanks.
I
Offline galannthegreat
Re: Wiring a Sharp IR Sensor GP2Y0D810Z0F
« Reply #1 on: November 17, 2009, 07:15:33 PM »
Pololu makes a very convienient breakout board for that sensor. They also give examples on using it.
Definately a good place to help you get started with it.
http://www.pololu.com/catalog/product/1133
Kurt
  • Helpful? 23
« Reply #2 on: November 17, 2009, 07:30:41 PM »
Thanks for that!
Probably going to need to order some x_x
I
« Reply #3 on: November 17, 2009, 07:46:34 PM »
It's all in page 2 of the datasheet.
- Vcc to pins 11 AND 14
- Gnd to pin 4
- 100nF between pins 4 and 11
- 100nF between pins 4 and 7
- Shunt pins 1 and 3
- 4.3 Ohm resistor between pins 2 and 4 (to set LED current)
- Pin 12 to pin 11 to activate (pin 12 to pin 4 for Stand By)
Output is now on pin 13, low when object is detected (2..10 cm in front of it), otherwise high
« Reply #4 on: November 17, 2009, 08:24:36 PM »
A2 is an unregulated pin on the Axon, and your sensor can't safely handle above 6.2V.
Just making sure you are aware of that ;D
  • Helpful? 23
« Reply #5 on: November 17, 2009, 11:59:47 PM »
@Admin:
I knew my battery was ~6V (5* AA rechargeables)
But ya.  I was rusty and finally went and looked at the schematic of the Axon again.  (But before I read your post, so hah! ;) )
And Thanks :)
@Soeren:
Thanks for translating that for me x)
I figured that'd probably tell me what I needed to know, but was hoping for a simpler solution.  Considering that I don't have a good supply of basic electronic components lying around, I need to either buy such, or just go with the breakout board.
Probably will do both, of course :)
I
Last post July 10, 2007, 12:24:36 AM
by Robotboy86
Last post October 16, 2008, 10:06:31 PM
by SeagullOne
Last post March 16, 2010, 06:31:34 AM
by richiereynolds
Last post May 10, 2013, 05:42:33 AM
by johnwarfin
