Author Topic: Shaft Extension for Wheelchair Motors  (Read 1711 times)
Offline TrumpkinTopic starter
« on: November 19, 2009, 06:27:59 PM »
I need to make the shaft on a couple of wheelchair motors longer, they have key seats on the shafts so I'm thinking of getting a couple of woodruff keys and using these: http://www.thebigbearingstore.com/servlet/the-1526/1-fdsh-2%22-Keyed-Shaft-Coupler/Detail along with some key stock, to attach this http://www.robotmarketplace.com/products/shafts_keyed_main.html and then use these: http://www.thebigbearingstore.com/servlet/the-5/1-fdsh-2%22-Pillow-Block-Bearing/Detail to reinforce the keyed shaft. There will be ~60 lbs on the shafts, so do you think this will work?
Robots are awesome!
Offline ArcMan
  • Mmmm... Plasma
Re: Shaft Extension for Wheelchair Motors
« Reply #1 on: November 20, 2009, 10:01:51 PM »
I'm not sure what you mean by "reinforce" the keyed shaft.  If you use 2 bearings on the keyed shaft which completely support the load, you'll be fine.  Just be sure you don't transmit any radial force to the shaft coupling. It cannont take it.
« Reply #2 on: November 21, 2009, 08:46:37 AM »
By "reinforce" I did mean "support the load". Thanks for the help.
Robots are awesome!
Last post September 04, 2007, 01:44:42 PM
by airman00
Last post December 05, 2007, 02:56:20 PM
Last post August 10, 2011, 04:10:00 PM
by corrado33
Last post March 23, 2013, 08:50:33 PM
by ROBOT420
