Author Topic: Servo position  (Read 921 times)
Offline Ecir HanaTopic starter
Servo position
« on: November 23, 2009, 07:19:45 PM »
Hello,
if I understand this correctly to move a servo to a certain position one has to drive the signal wire with desired PWM value so long until it finally moves there. Is this correct? How do I know then if the servo is already in the position or if it is just moving there? I mean, a servo is left and I want to turn it right - how to I know that it stopped moving and is on the right hand side?
Offline madchimp
Re: Servo position
« Reply #1 on: November 23, 2009, 07:39:19 PM »
Hobby servos don't have feed back so you have to just trust that they will go to where you tell them. There are ways to add position feed back to them though.
Re: Servo position
« Reply #2 on: November 24, 2009, 11:23:38 AM »
[...] drive the signal wire with desired PWM value so long until it finally moves there.
You make it sound really slow.
What's the reason you need to know?
Oh well, either detect position optically or measure the current draw.
Re: Servo position
« Reply #3 on: November 24, 2009, 10:00:10 PM »
I wanted to perform a sequence of action based on the completion of previous steps.
Ha! Actually, thanks a lot! If the servo doesn't make any noise - it's there! Just wire up some mic to ADC... Or hall sensor for the rotor...
« Last Edit: November 24, 2009, 10:01:35 PM by Ecir Hana »
Offline madsci1016
  • Helpful? 43
Re: Servo position
« Reply #4 on: November 25, 2009, 12:09:50 AM »
...or a current sensor to the servo!!! ( as stated before)
That would be a better idea as it would be immune to interference. The mic would pic up everything making noise.
Last post March 08, 2009, 08:07:50 AM
by BEAMer
Last post April 01, 2010, 08:00:18 AM
by Antonb
Last post December 15, 2010, 09:46:29 PM
Last post September 15, 2011, 07:22:02 AM
by mstacho
