Author Topic: How to convert 5V to 3.3V  (Read 5626 times)
Offline Ecir HanaTopic starter
« on: November 25, 2009, 01:24:10 PM »
Hello,
I have 5V of regulated voltage (USB) and I would like to get from it 3.3V. How to do it? I read that one possibility is to build "voltage divider" (2 serial resistors, maintaining voltage ratio), (Zener) diodes which drop some voltage, voltage regulators, ....
What is the best way to do it? I need quite steady voltage (to power a microcontroller), max. 1A. I would prefer some integrated circuit but I don't know which one - LM3940? LM317? L78L33ACZ? or something else? Or the simple divider would be the best option?
« Last Edit: November 25, 2009, 01:29:36 PM by Ecir Hana »
Offline rollingrobot
Re: How to convert 5V to 3.3V
« Reply #1 on: November 25, 2009, 01:48:31 PM »
You would need a 3.3V regulator  :-X
SparkFun would have them. Just put it on a small PCB proto board. Make some pins to connect from your current source of voltage to the regulator than connect the regulator output to your board.
« Reply #2 on: November 25, 2009, 02:11:59 PM »
Yes, but which one? There are very many of them... Does it even matter? Just some voltage regulator which can handle enough mA?
« Reply #3 on: November 25, 2009, 02:20:15 PM »
Also, LM3940 is more than 10x expensive than the two dividing resistors - what's the difference?
« Reply #4 on: November 25, 2009, 02:42:31 PM »
If you are only gonna use up to eg. 1mA, you could get away with a resistive voltage divider, but it won't have any regulation.
You need an LDO regulator (Low Drop Out), as eg. an LM317 (or the 78 series) needs to drop 3V, leaving you with only 2V at the output.
An LDO can have a drop of less than half a volt or less (down to <0.1V if a high current device is used with low current).
« Reply #5 on: November 25, 2009, 02:52:18 PM »
I see, thanks a lot for the explanation!
Last post April 03, 2007, 02:40:30 PM
by Ratfink
Last post November 16, 2009, 08:01:04 AM
by dsesmg
Last post January 09, 2010, 09:31:10 PM
Last post May 08, 2010, 04:12:03 AM
by SmAsH
