Author Topic: Servo coding for the ATmega8  (Read 2742 times)
Offline PierreTopic starter
« on: November 26, 2009, 10:48:00 PM »
Hi
     I am having difficulties with C codes with the modified servo.
     My goal is to make the servo spin:
          1. Go left Counter clockwise(ccw) using OCR1A 1000 or 1ms;
          2. Go right clockwise(cw) using OCR1A 2000 or 2ms ; and
          3. stop.  using OCR1A 1500 or 1.5ms
The theory says so but not for me
     Problems I have are:
          Values for OCR1A:
               1.  Stop:  825 stops but keep getting twitches(reset);
               2.  Left(ccw):  1200 goes left for one (1) seconds stop and goes again.  It goes fine if I unplug it for 2 sec then put it back on; and
               3.  Right(cw):  540 full right(cw) no problems .
I seem to be using the right telemetry in the register.
     Clock for ATMega = 1 000 000
     Prescale = 1
     getting 50Hz with prescale at 1 and ICR1 at 10 000
     WGM13 at 1
     Here is below C codes I am using.  It is poor C programming but it is a start.  Hope anyone could see what I am missing.
#include<avr\io.h>
#include <util\delay.h>
#define F_CPU 1000000UL
int main(void)
DDRB=(1<<PB1); //set OC1A as output pin
TCCR1A = 0x80; //set OC1A to bottom
// Ask for non-inverted PWM on OC1A and OC1B
   TCCR1A = (1 << COM1A1) | (1 << COM1B1);
TCCR1B =(1<<WGM13) | (1<<CS10);//phase and frequency correct PWM | Prescaler n=1
ICR1 = 10000;  //(MCU_FREQ = 1000000/(2 x n=1 x 10000)) = 50Hz
OCR1A = 2000;   //initial value
Now that I have wrote this.  Having a loop inserted could probably fix the reset I get every second or so.
Thank you in advance for any help I may get
  • Helpful? 111
Re: Servo coding for the ATmega8
« Reply #1 on: November 26, 2009, 11:18:35 PM »
