Author Topic: want to measure gauge of a sheet .  (Read 997 times)
Offline karmaxTopic starter
« on: November 27, 2009, 11:25:36 AM »
i want to make a device which can measure gauge of a sheet .i have machine in which plastic sheet always moves and during that time i want to measure gauge of sheet any help will be appreciated
Re: want to measure gauge of a sheet .
« Reply #1 on: November 27, 2009, 12:19:00 PM »
If the plastic sheets are of the same material each time, a capacitive sensor could be used.
If they are of the same color (and material) and more or less translucent to infrared, that might be a way to go.
Or you could go extremely low tech and make a mechanicel sensor (perhaps with an electronic readout).
Would it be for a adjusting the gauge of the sheets, or whar is the purpose of measuring it?
« Reply #2 on: November 28, 2009, 10:43:38 AM »
first of all thanks a lot for replying alll time material are of diff type thats the main problem.we have to make some product of constant weight and weight is defined by gauge of sheet .thats why i want to constantly measure gauge if there is any problem i can shutdown the machine and change the sheet
« Reply #3 on: November 28, 2009, 02:08:27 PM »
What measures are possible and what tolerances are needed?
Does the sheets run over a hard roller at some place?
« Reply #4 on: November 30, 2009, 10:07:15 AM »
actually our final product depend on  gauge of sheet .so i want to constantly see the gauge of sheet .ya sheet run over a hard roller some place is it matters?
« Reply #5 on: November 30, 2009, 01:54:19 PM »
[...] ya sheet run over a hard roller some place is it matters?
It may  make things easier for you.
You can get a away with using a less precise sensor arrangement if you make something like this:
Still, without knowing the range of possible gauges and the tolerance needed, it's hard giving specific advice about the sensor.
Last post November 02, 2006, 11:39:01 AM
by JesseWelling
Last post December 13, 2009, 06:48:05 PM
by Joker94
Last post January 12, 2011, 10:38:49 PM
by Joker94
Last post October 24, 2011, 12:39:54 PM
