Author Topic: my LCD shows only solid block  (Read 1029 times)
Offline CharizardTopic starter
« on: November 28, 2009, 12:35:18 AM »
Hi, I am planning to allow my robot to sense temperature, then at certain temperature, the LED will light, fan work and the LCD display the temperature. I am using PIC16f877a, the pin connection between LCD and PIC looks like this,
LCD =>PIC
DB0~DB7=> RB1~RB7 (portB)
RS =>RD7
E =>RC7
 However, when i try to run it, the LCD just show solid block in the first line. After troubleshoot for quite sometime, i couldn't find the root prob, can anyone help me with this? Here is my code in the attachment. I look at the datasheet, it says that port B has weak pull up, do I need to disable it?
Thanks.
Offline Trumpkin
Re: my LCD shows only solid block
« Reply #1 on: November 28, 2009, 10:29:37 AM »
What LCD are you using? Solid black means the LCD is not initializing properly.
Robots are awesome!
« Reply #2 on: November 28, 2009, 02:48:28 PM »
It is a 2x16 LED. I tried to modify the code to show the same character for line1 and line2 of the LCD;yet it still only show solid block in first line,and line2 is blank. The LCD not initialized properly means is the pin assignment in the code problem?
Last post May 26, 2008, 08:41:47 AM
by airman00
Last post February 15, 2009, 11:47:25 AM
by DemonDomen
Last post September 14, 2009, 05:27:05 PM
by Pierre
Last post December 14, 2010, 02:06:04 PM
by Webbot
