Author Topic: servo calibration  (Read 2795 times)
Offline amandeep1Topic starter
servo calibration
« on: November 30, 2009, 07:00:14 PM »
hey i followed this tutorial to modify my servos
http://www.kronosrobotics.com/an116/GAN116at.shtml
i am at the last part to calibrate them however i am confused. i just put random code in arduino to make it spin 360 degrees front and then go back and repeat. then i kept moving the pot until it stopped moving. did i do this right? what is the purpose of calibration?
thanks and sorry if this is dumb question i am beginner  ;D
Offline Gertlex
  • Helpful? 23
Re: servo calibration
« Reply #1 on: November 30, 2009, 10:34:36 PM »
The point of calibration is to set the servo such that it doesn't rotate when at the centered position (127 on a 0 to 255 bit range, or 1500µs).  That way, you always know what value to send via code to stop the servo.
So put code into the arduino that would center an unmodified servo.  With this signal being sent to your modified servo, it will rotate if the potentiometer is not in the centered position.  The servo uses the potentiometer to judge the position.
Hopefully that explains it well enough.  I could explain more in depth how the potentiometer position is "judged", but that's not needed at this point, I think.
I
« Reply #2 on: November 30, 2009, 11:16:59 PM »
ok thanks so if i am using the servo library for arduino
myservo.write(127);
should work or do every servo have a different position center position?
also i don't want to make a new topic so i will ask here. are there good tutorials or guides to make a 5v regulator.
« Reply #3 on: December 01, 2009, 09:34:23 AM »
myservo.write(127);
If you output the 1.5ms pulse, you can adjust any servo to stop, to make them alike (no guaranties for the extremes though).
You're thinking of using a 5V regulator (the ones that the IC manufacturers make), right?
Or do you want to make a regulator from discreetes/op-amps and such (that's not a subject for a beginner)?
« Reply #4 on: December 01, 2009, 06:34:57 PM »
sorry meant using
any suggestion?
Offline Gertlex
  • Helpful? 23
« Reply #5 on: December 02, 2009, 09:59:38 PM »
If your servos get damaged by being held against turning or some such, you can end up with some that don't center properly.  For example, I have a used metal geared servo that I got off ebay that doesnt' center properly :/
But ya, that's just trivia at the moment.
(Can't help ya on 5v regulators)
I
« Reply #6 on: December 03, 2009, 08:16:40 PM »
how are you guys powering the servos?
Last post September 01, 2008, 04:36:57 PM
Last post February 23, 2010, 08:19:10 AM
by wheelyneil
Last post August 31, 2011, 10:05:16 AM
Last post April 27, 2012, 05:28:56 PM
by DivideByZer0
