Author Topic: solder sucker not working  (Read 2478 times)
Offline NOOBinDistressTopic starter
« on: April 28, 2007, 08:30:55 PM »
I am the one who need help with my board soldered wrong. Someone said a solder sucker would work.I just wanted to tell you that the solder sucker didnt work . What a waste.I guess it is still good for other projects. Now I have to reorder the parts. I knew the 15 watt soldering iron would not work. thanks anyway.
Offline Somchaya
  • You know it's cute!
Re: solder sucker not working
« Reply #1 on: April 28, 2007, 08:52:58 PM »
Hmm.. can you elaborate on how it doesn't work?
I still think it'll work given some tries :P
Somchaya - Back after a year of misc things
http://whisker.scribblewiki.com
Offline sdk32285
« Reply #2 on: April 28, 2007, 09:14:00 PM »
They can sometimes be tricky to use when manipulating your iron and the sucker at the same time,
Make sure the solder is melted when you push the button to "suck up" the solder
Offline trigger
  • It's an op amp, not a gun part.
« Reply #3 on: April 28, 2007, 10:03:44 PM »
I've found that a wick is easier for me to use than a solder sucker.  You stick it on the solder and stick the iron on the wick, and the wick magically sucks up the solder.
There are 10 kinds of people in this world: those who can read binary, and those who can't.
Offline Somchaya
« Reply #4 on: April 28, 2007, 11:20:09 PM »
Yeap.. if the solder cools and hardens too quickly, leave the soldering iron on the melted solder for a while so it heats a little above the melting point before sucking.
Offline Hal9000
« Reply #5 on: April 29, 2007, 05:49:42 AM »
Get a trusty mate to do the sucking.............much like a dentist's assistant
« Reply #6 on: April 29, 2007, 07:47:40 AM »
well like I said before the 15 watt is not hot enough.
Offline sdk32285
« Reply #7 on: April 29, 2007, 08:36:59 AM »
If 15W can be used to melt the solder originally, cant it remelt the solder...
hold the iron on the solder while sucking
Last post January 24, 2007, 07:29:40 AM
by JonHylands
Last post April 26, 2007, 02:42:58 PM
by ed1380
Last post February 14, 2010, 10:20:44 PM
solder
Started by g44 Electronics
Last post April 04, 2010, 09:45:45 PM
