Author Topic: Some questions reguarding a specific gearmotor, wheels and stuff  (Read 1585 times)
Offline vagoirTopic starter
« on: December 03, 2009, 07:23:08 AM »
Greetings,
this is my first post to this wonderful site :)
so my problem is that i recently bought this gearmotor: http://www.robot-italy.com/product_info.php?cPath=8_90&products_id=483 but i have no idea how I can attach a wheel to it...what parts do I need? and also what parts do i need to mount the motor to the robot chasis.
I'm an electronix student but this is the first time i try to build a robot.
thank you for you help :)
Re: Some questions reguarding a specific gearmotor, wheels and stuff
« Reply #1 on: December 03, 2009, 07:56:01 AM »
You need a wheel or hub with a 4mm hole and set screw to lock onto the motor shaft.
Here is a hub:
http://www.robot-italy.com/product_info.php?cPath=7_40&products_id=401
and wheels:
http://www.robot-italy.com/product_info.php?cPath=7_39&products_id=385
That looks to be a nice motor. Wonder if they ship to the USA?
« Reply #2 on: December 04, 2009, 08:41:19 AM »
Hi,thanks for the quick reply :)
I didn't know why but i also bought those two that u mentioned :) but this specific wheel has no holes for screws and I have no Idea how i will mount the hub to the gearmotor  :-\ .Sorry if it sounds funny but is there a tutorial for this, I have no idea what to do  ???
once again thank you for posting
« Reply #3 on: December 04, 2009, 12:21:29 PM »
The hub should just slide onto the gear motor shaft and then locked on by tightening the set (grub) screw.
You will need the drill hole in the wheel to match the hole pattern on the hub. Then use the long screws that come with the hub to bolt the wheel and hub together.
