Author Topic: CMUCam2 + Axon problems  (Read 987 times)
Offline weijie90Topic starter
« on: December 04, 2009, 03:33:46 AM »
I have a CMUCam which works via Bluetooth. According to its response to the GV command, it is a CMUCam2 v1.00 c6. THe SJ command also works.
I am trying to use the Axon to pipe the output of the SJ (send JPEG) command to the PC via rprintf. However, all I get is
��u�ŭ�EҎ� ����
and then -1s (not shown).
The code I'm using is:
void cmucam_init(void) {
    uart0SendByte('R');
    uart0SendByte('S');
    uart0SendByte('\n');
    delay_ms(500);  // wait 500 milliseconds
    uart0SendByte('R');
    uart0SendByte('M');
    uart0SendByte(' ');
    uart0SendByte('1');
    rprintf("CMUcam Initialized\n");  // send out the message through USB
void cmucam_test(void){
    uart0SendByte('s');
    uart0SendByte('j');
    uart0SendByte('\r');
    int c;
    int i;
    for (i = 0; i < 10000; i++){
        c = uart0GetByte();
        if (c != -1){
            rprintf("%c", (char)c);
    rprintf("\n\nOK");
    /*Receive_Echo(6000);*/
................ In main() ..................
cmucam_init();
cmucam_test();
................ In Axon.c .................
uartSetBaudRate(0, 115200); // set UARTE speed, for the CMUCam
What's going on? I don't think it's an issue with UART bit errors, because I get so little data.
Any help would be greatly appreciated. Thank you so much!
Re: CMUCam2 + Axon problems
« Reply #1 on: December 04, 2009, 08:20:48 AM »
I think its
    uart0SendByte('\r);     not    uart0SendByte('\n');
« Reply #2 on: December 04, 2009, 08:34:01 AM »
Ok, but the SJ command does give an \r.
Last post January 20, 2009, 08:12:29 PM
by Jdog
Last post March 25, 2009, 01:16:27 PM
by Webbot
Last post June 07, 2009, 10:18:01 AM
by zuazons
Last post September 26, 2009, 12:09:36 AM
by JadeKnight
