Author Topic: 50$ robot photoresistor  (Read 2543 times)
Offline razvanc_roroTopic starter
« on: April 29, 2007, 11:06:16 AM »
Can someone tell me what value is the resistor from the photoresistor used for the 50$ robot?
            340ohm resistor
OR
            1.62Kohm resistor
Thank you!
Try do your best without doing anything! Possible?!?
Offline TravelingPencil
Re: 50$ robot photoresistor
« Reply #1 on: April 29, 2007, 12:35:46 PM »
when i built the 50$ robot i used a random one from the assortment that i got at radio shack.
Offline ed1380
« Reply #2 on: April 29, 2007, 02:44:57 PM »
the 1.62k.
 you could have easily found out, by using the color code guide and the pics.
Offline iCopyright_Everything
« Reply #3 on: July 20, 2007, 01:03:49 AM »
Hi guys,
Firstly, DO forgive me if by any chance I have duplicated a question here but I have searched the forum for this and come a-cropper...
I am in the UK & totally new to Robotics. For the $50 robot, I CANNOT order from Radio Shack (US only)
So what I need to know please is the properties of a good photoresistor to use for the $50 bot. Let me copy n paste what Ive found for it in british websites (light dependent resistors -- bloody british electronics companies dones even seem to HAVE the WORD Photoresistor in their lexicon!)
CHARTLAND
Order Code: 7482280
Manufacturer Part No: N5AC501085
RoHS :
Description
    * Light Dependant Resistor
    * Resistor element type:Light Dependent
    * Wavelength, spectral response peak:650nm
    * Series:NG
    * Resistance, @ lux A:100kR
    * Voltage rating, DC:100V
    * Case style:Radial
    * Depth, external:4.6mm
    * Diameter, lead:0.5mm
    * Length / Height, external:3.2mm
    * Length, lead:34mm
    * Power dissipation:50mW
    * Resistance, @ lux A max:100kR
    * Resistance, @ lux A min:50kR
    * Resistance, dark:5MR
    * Temp, op. max:60?C
    * Temp, op. min:-30?C
    * Wavelength, peak:550nm
    * Width, external:5.3mm
-------end of quote------
Is this appropriate?
PLEASE advise me ASAP as Ive ordered all the other stuff. Thanks!
« Reply #4 on: July 21, 2007, 06:26:00 AM »
As far as the $50 robot is concerned, if it looks similar to the one in the pictures, it will work fine for what you want.
There are only two concerns with any photoresistor:
1) response time - dependent on size and quality of the photoresistor
2) change in resistance wrt light absorbed
A browse at the datasheet should be able to tell you if it is acceptable.
Looking at your posted specs, that photoresistor looks acceptable to me.
Last post June 27, 2007, 07:01:58 PM
by sdk32285
Last post March 17, 2008, 01:29:30 PM
by superchiku
Last post April 12, 2008, 02:09:38 PM
by cooldog
Last post August 26, 2012, 01:42:02 AM
by y3d1j4
