2
Author Topic: printing from eagle  (Read 3425 times)
Offline cooldogTopic starter
printing from eagle
« on: December 04, 2009, 09:56:07 AM »
so i got a eagle board done. and i want to print it. it is two sided. how do u guys print it so that only the bottom layer is printed or only the top?
i tried changing viable layers but the boards came out different sizes.
-admin
favorite web sites
http://www.societyofrobots.com/
http://www.instructables.com/
Offline TrickyNekro
  • Helpful? 15
  • 1.6L Peugeot 307 tuner
Re: printing from eagle
« Reply #1 on: December 07, 2009, 05:25:53 PM »
Noway, unless you change the scale factor there is no way that gonna happen,
check the frame side of the two boards, if it's the same
Cheers!
Offline Trumpkin
« Reply #2 on: December 07, 2009, 07:54:19 PM »
Here's a tutorial I found for printing out Eagle boards, http://www.cnczone.com/forums/showthread.php?t=33374 a bit over complicated but it works just fine. I printed out two layers of a circuit following this tutorial and it came out the same size.
Robots are awesome!
« Reply #3 on: December 07, 2009, 08:23:56 PM »
thanks :) ill give it a try
-admin
favorite web sites
« Reply #4 on: December 08, 2009, 11:56:30 PM »
http://www.societyofrobots.com/electronics_Eagle_export_tutorial.shtml
Each file represents a different part of the board. Just look up which ones represent the upper layer.
Or if you meant printing with a paper printer, just turn off the layers you don't want to see (in the top drop down menu).
