Author Topic: Axon II battery connector, hitec or futaba?  (Read 1641 times)
Offline chelttownTopic starter
« on: December 12, 2009, 03:53:56 PM »
Hi, I have just ordered the Axon II, but am finding it difficult to find a battery and charger with a hitec conector.
I have managed to find lots with Futaba connectors, would these work/fit the switch that comes with the Axon. I am in the UK so need a site that is based here really.
The one I am talking about are here http://www.vapextech.co.uk/acatalog/copy_of_High_Power_Model_Control_Batteries.html
Im sorry if this has been talked about before, but I could not find anything about it.
Many thanks
Chelttown
Offline rollingrobot
Re: Axon II battery connector, hitec or futaba?
« Reply #1 on: December 12, 2009, 04:16:23 PM »
http://www.societyofrobots.com/actuators_servos.shtml
The last paragraph of that web page shows you how to modify the futaba connector to a hitec connector.
I think you can remove the housing of futaba and put a housing of the hitec, I'm not sure though.
If you don't have any success with that you can cut off the entire futaba connector itself, leaving two pieces of wires and follow this tutorial on manually putting a hitec connector. If you going with the last option you can buy crimpers very cheap at http://servocity.com html/servo_connectors___pins.html and you can buy necessary pins/housing.
« Reply #2 on: December 13, 2009, 04:11:56 PM »
Thanks for the link.
Does anyone know where to buy a charger in the uk with a hitec connector?
  • Helpful? 107
« Reply #3 on: December 13, 2009, 09:20:08 PM »
I've bought them from vapextech before.
Just use the 'futaba' ones and clip/file off the 'flange thingy' on the side of the connector to make it a hitech
vapextech also sell chargers with futaba connectors
« Reply #4 on: December 14, 2009, 02:56:18 AM »
Thank you very much for your answer that is exactly what I wanted to know  ;D
Cheltttown
« Reply #5 on: December 14, 2009, 06:25:18 AM »
You also need to file down two corners after you cut off the flange thingy. If you look at the female Hitec connector on the on/off switch, you'll notice its not exactly a perfect square.
Just use sandpaper, or an emery board (for filing nails), to get it to fit. Its a quick 5 minute job.
Last post June 12, 2007, 07:09:50 AM
Last post April 26, 2008, 06:41:36 PM
Last post June 21, 2008, 12:13:49 PM
Last post March 01, 2009, 10:20:46 AM
by kd5kfl
