Author Topic: New here: some simple questions on the Axon2  (Read 1869 times)
Offline KurtEckTopic starter
  • Helpful? 12
« on: December 12, 2009, 08:40:37 PM »
Hi, I am new to these forums,
Today my Axon2 arrived :)  It has been a little while since I have done any programming on an AVR based system.  Previously I did some with the Atmega32 (SRS workshop robot) and Atmega128 (BDMicro Maveric).  I have been meaning to do some more with the ATmega and I really liked the design of the new board as it is a lot easier to add things on to this board then I could do with the Maveric!
Currently I do most of my deveopment on Lynxmotion robots using the Basic Micro BAP28 microcontoller in Basic and some H8 assembly language.
So I decided to start working my way through the Getting started tutorial and cam up with a couple of questions and/or observations.
Setting up Software: Step 6, you mention you need to add the libraries in a certain order, but I dont think this order is matched in the shown image.
In steps 7-8: The program did not complile.  The main problem is that it could not find a header file: servopwm.h.  Looking through the header files, I tried servos.h and the program did compile after that.
I went on to the hardware page and installed the usb driver and the like.  I then went on the bootload page and tried to download the bootloader and I get an error: /axon2/downloads/FBOOT17.EXE does not exist on this server.
I tried a couple of things like, maybe you were up to version 18 or 19 or 20, but same error, so finally found what I think the file is the right file at /axon/downloads/FBOOT17.EXE.
That is all for now, again I think this should be a lot of fun.  Later I may have more questions about using the USB boot loader versus using AVRISP or AVRJTAGICE_MKIIā€¦ But for now I will keep this simple.
Kurt
Re: New here: some simple questions on the Axon2
« Reply #1 on: December 12, 2009, 08:57:10 PM »
I had an Axon... I found that the bootloader took maybe 20 or so seconds to download, which got kind of annoying. I got the AVR ISP MKII and now it downloads in seconds. IMO it is worth the money.
Offline madsci1016
  • Helpful? 43
« Reply #2 on: December 12, 2009, 09:30:47 PM »
You have (had) WinXp SP3. It's documented on the main website that SP3 adds 30-40 seconds to the flash time. I had this problem as well, i rolled back to SP2 and flash times went back to ~5 seconds.
  • Helpful? 12
« Reply #3 on: December 12, 2009, 09:34:54 PM »
thanks for the heads up.  I am actually on Windows 7.  I also do own a AVRISP and the Jtag.  Will have to see if I have the right converters or the like as my ISP has 10 pins.
Offline rollingrobot
« Reply #4 on: December 12, 2009, 09:42:38 PM »
For only $1 you can get a nifty converter board (you have to do the soldering)
http://www.sparkfun.com/commerce/product_info.php?products_id=8508
Of course, there is always looking for a schematic and do it yourself on a protoboard/breadboard
« Reply #5 on: December 14, 2009, 06:04:50 AM »
As an early user of the Axon II, you are a victim of all my typos . . . but you did a pretty good job getting around them!
Actually, only the libWebbot-ATmega640.a file needs to come first. The others can be in any order. I corrected the documentation, sorry for the confusion.
Oops. WebbotLib combined servopwm.h and servos.h in a recent version. I corrected for it, and even uploaded it, but its still linked to old code . . . use the photovore example in here:
http://www.societyofrobots.com/axon2/downloads/Axon_WebbotLib_examples.zip
oops, link corrected
http://www.societyofrobots.com/axon/axon_FAQ.shtml#boot_slow
I personally prefer to use the ISP programmer simply to avoid the annoying turning on and off of hyperterminal to program.
ps - I updated everything locally, but it won't get uploaded until I fix the FTP on my site . . . long story . . .
  • Helpful? 12
« Reply #6 on: December 14, 2009, 08:34:42 AM »
Thanks!
I ordered the 10->6 converter board from Sparkfun so will probably go this way for awhile.  May also convert over my JTAG.
Thanks again
Kurt
