Author Topic: Blackfin camera console - cp2102  (Read 1570 times)
Offline pchanTopic starter
« on: November 29, 2009, 11:30:34 PM »
im trying to use the cp2102 si-labs converter, however im not having any success connecting with the blob java console, i only wired up the rx and tx lines, is cts/rts required as well for hardware flow control? has anyone else had luck with the cp2102?
« Reply #1 on: November 30, 2009, 12:14:17 AM »
i grounded pin-17 on the srv-1 to disable hw flow control, this did the trick. cp2102 works with just tx/rx connected, thanks all for the info.
from uart.c line starting from 126:
void uart0SendChar(unsigned char c)
    while (*pPORTHIO & 0x0001)  // hardware serial flow control -
        continue;               //    S32 pin 17 should be grounded to disable
    while (!(*pUART0_LSR & THRE))
        continue;
    *pUART0_THR = c;
Offline hgordon
  • Helpful? 7
« Reply #2 on: November 30, 2009, 10:14:11 AM »
Exactly.  Note that pin 16 on the 32-pin header is GND, so you just need to connect pin 16 <=> pin 17 to override the hardware flow control.
Surveyor Corporation
  www.surveyor.com
Last post October 12, 2008, 07:43:33 PM
by hgordon
Last post November 05, 2008, 06:33:03 PM
by TyLEr71
Last post November 28, 2009, 11:46:47 AM
by hgordon
Last post June 12, 2010, 06:51:05 PM
by javila
