Author Topic: accurate sensor to measure distance 0cm - 100cm  (Read 1213 times)
Offline mcwee67Topic starter
« on: December 16, 2009, 06:08:40 AM »
Hello,
I'm a student doing my final year project on making a robot which can navigate through a corridor.
I have been using infrared sensors to measure distance but I got reading from all over the place.
I have looked at ultrasonic sensor for measurement, but can anybody recommended anything other sensor, I heard laser is good but extremely expensive to build...?
Re: accurate sensor to measure distance 0cm - 100cm
« Reply #1 on: December 16, 2009, 07:23:22 AM »
Sharp produces a range of IR sensors that's pretty good. Read on here http://www.acroname.com/robotics/info/articles/sharp/sharp.html
« Reply #2 on: December 16, 2009, 07:43:20 AM »
Thanks...
I'm using one of the sharp sensor, but my problem is that it gives number of different reading...
I have run test of taking measurement of 100 at 15cm, 20cm, 25cm, 30cm etc... and the results have .0 of a change...
I've looked at ultrasonic... are they more accurate then infrared?
« Reply #3 on: December 16, 2009, 04:07:01 PM »
Then you did something wrong - they're very reliable.
Did you place a cap over the supply lines, directly at the sensor?
On the contrary.
« Reply #4 on: December 16, 2009, 04:24:53 PM »
Sorry what do you mean by "Did you place a cap over the supply lines, directly at the sensor"???
How would I go about getting accurate measure from a sharp sensor?
« Reply #5 on: December 17, 2009, 04:27:19 PM »
Excactly what I asked (cap = capacitor), what puzzles you  about it?
I take it that you didn't, so try that.
What model number is the Sharp sensor you used?
Apart from decoupling the supply lines by the cap, I'd just measure its output.
Last post November 16, 2007, 11:34:36 PM
by HDL_CinC_Dragon
Last post May 15, 2007, 04:40:35 AM
Last post October 08, 2008, 05:52:20 AM
Last post February 17, 2009, 06:49:16 PM
by MaltiK
