Author Topic: making ur own software  (Read 1302 times)
Offline gaurav.pTopic starter
  • Go robotics
« on: December 19, 2009, 01:07:55 AM »
hello guys,
i wanna ask how to make my own software coz i m trying to control the movement of the robot using serial i want to make a software which could have buttons which when clicked will result in the movement of the robot.can anybody suggest how to make ur own's software .
PS-like there can be another software which can be used by taking the readings of the ping sensor and thus in this way create a map  of the given location.
Big Things Come In Small Packages!!!
Offline blackbeard
Re: making ur own software
« Reply #1 on: December 19, 2009, 10:11:55 AM »
first you need to earn how to program in one or more languages. the one that is used in allot in hardware control is "C" which has various free compilers including one called visual C by microsoft. there's also open source versions such as "processing" which is used by the arduino. you should do some research before getting into programming as it is often quite an undertaking to learn a programming languige without any base.
Next step: Give them vaginas
