Author Topic: sound dampening noisy motors  (Read 2666 times)
Offline Brandon121233Topic starter
« on: April 30, 2007, 04:49:00 PM »
Hey guys
I just got my Banebots gearhead motors, they're really powerful and well made but pretty noisy. Does anybody know of any techniques for sound dampening motors? I was thinking like wrapping it in foam, or mounting it with rubber grommets. If anyone has had experience with making things less noisy or can give me some advice, it would be greatly appreciated.
-Brandon
        —Thomas Edison
Re: sound dampening noisy motors
« Reply #1 on: April 30, 2007, 05:24:42 PM »
what type of sound?
is it gears grinding? use grease/W-40. or a humming noise? increase the PWM frequency until you cant hear it.
I dont recommend foam . . . motors overheat, and foam acts as a thermal insulator. I once fried a motor cause I placed it inside styrofoam . . .
« Reply #2 on: April 30, 2007, 06:18:20 PM »
Here are the motors http://www.trossenrobotics.com/store/p/5133-64-1-24mm-Planetary-Gearmotor-RS-370.aspx , and a sound of them. It's because of the planetary gears- I know that so theres nothing wrong with them, I just want to know if there are methods of greatly reducing this noise.
[youtube=425,350]F80Ak5MFSuU[/youtube]
« Last Edit: April 30, 2007, 06:23:39 PM by Brandon121233 »
        —Thomas Edison
« Reply #3 on: April 30, 2007, 06:32:19 PM »
wtf that sounds horrible! something is wrong with that gear box . . . try putting WD-40 into it, run it for a bit, and see how the noise changes.
I suspect a gear is damaged, is this a new motor? any chance you can open it up to see the gears?
worse case scenario, you can put foam around the gear box (not motor) to dampen it a bit . . .
« Reply #4 on: April 30, 2007, 06:59:26 PM »
Yeah I'm not sure, one of them the one I recorded sounds like that, the other is about half as noisy and runs a little smoother. Maybe I get a defective gearhead? I think I'll open it up and see if anything looks out of place.
        —Thomas Edison
Offline nanob0t
  • Trust Your Technolust
« Reply #5 on: May 01, 2007, 04:11:22 AM »
Haha, I thought that clip was halarious.  I agree with the admin, it sounds like something inside is grinding or there is a flaw in one of the gears.  One of the sounds isn't constant, you can hear a clicking inside, which indicates to me, there may be a flawed part in the middle
« Reply #6 on: May 01, 2007, 04:08:05 PM »
heres both of them, the ok sounding one and the one that I think is broken (in a real video!).
[youtube=425,350]5yt4uj7cIII[/youtube]
        —Thomas Edison
Offline ed1380
« Reply #7 on: May 01, 2007, 04:20:12 PM »
To be honest they both sound the same
Last post April 28, 2010, 07:05:17 PM
Last post October 28, 2008, 07:36:40 AM
by Tsukubadaisei
Last post July 09, 2009, 07:32:28 PM
Last post December 23, 2011, 03:37:35 PM
by ArtBot
