Beginners: please read this post and this post before posting to the forum.
Thanks Scadabg but from where do i get it.cheers
I think you do not need a MAX 232 IC between the USB to serial converter you are using and your microcontroller. I guess the USB to serial converter itself gives you +0 and +5 V outputs. Could you post a picture of the converter you are using.
@ Soeren, I have posted the details earlier of the voltage levels that i get when the transmitter is ideal, what do you suggest? does the data seems ok... should i proceed.
Started by SeagullOne Electronics
Started by pduncan Electronics
Started by sacre Electronics
Started by voyager2 Software
