Author Topic: modified servo-->different direction, different speed...??  (Read 923 times)
Offline manutTopic starter
« on: December 30, 2009, 07:12:03 PM »
hi,
I modified a new servo, I already succeeded with two other ones..
this one works, but doesn't have the same speed if it's forward or backward...
I used the 2.2k resistors for the modif...
does somebody know where it could come from..?
thanx
manu
Re: modified servo-->different direction, different speed...??
« Reply #1 on: December 30, 2009, 07:16:06 PM »
Were the 2k2 resistors 1% tolerance?
« Reply #2 on: December 30, 2009, 07:41:51 PM »
it's actually a gold stripe..so 5%..right? ...I controlled the resistance with my multimeter before to solder them..it was 2.17k, both of them.. Do you think it could be  the cause of my prob? I thought that a so small difference wasn't important, but...
« Reply #3 on: December 30, 2009, 07:43:55 PM »
I'm not sure if its the cause of your problem but they're supposed to be precision 1% resistors?
« Reply #4 on: December 30, 2009, 07:51:12 PM »
okay, I'll try with 1% tolerance, because I did it two times exactly the same way but the resistors were exactly 2.2k (measured with the multimeter)..
thanx
« Reply #5 on: December 31, 2009, 07:00:11 PM »
Most 5% resistors are way closer than 5%
Besides, it doesn't matter, if the servo is steady at 1.5ms, it's close enough and they don't have to be 22k! eg. 10k, 47k or 100k will be just fine, as long as they're the same value. They are just there to establish a midpoint for a stopped servo at 1.5ms, nothing else!
Last post November 13, 2008, 01:28:14 AM
Last post December 15, 2008, 06:07:43 PM
by leeguy92
Last post June 22, 2009, 04:16:56 PM
by Ro-Bot-X
Last post October 07, 2009, 09:54:14 PM
by mattscott251
